It`s ALIVE
Fired it up at 2:05 PM & let it run til 2:30 !!
no real issues , it fired up immediatly & stalled as the choke was not connected , restarted immediatly , no problems & ran great for 25 mins . I let the engine cool down & installed the inner valve spring & reset the valve lash & started it again & set up the idle mixtures ,small leak from the valve cover gasket on re-install I had to correct & I seem to have a bad water pump as I have a small drip from the water pump so I guiess I wil have to get a new one .
It seems to be very responsive & runs great for only running 30 mins
