Author Topic: Timing adjustment  (Read 764 times)
Offline Katfish
  • 70 Challenger
Timing adjustment
« on: November 08, 2008 - 02:57:28 PM »
I set my timing to 36* at 3000rpm, with vacuum connected it went to 52* @ 3000rpm, and 15* at idle.
When I took car for test drive I thought it had slight ping when I got on it.
I readjusted the timing at idle to be 10* BTC and the ping went away.  Is the correct method for adjustment?
Thx
Re: Timing adjustment
« Reply #1 on: November 08, 2008 - 03:34:55 PM »
I leave the vacuum disconnected or at least insert an allen wrench into the vacuum pot  & limit the travel to 2-3 *
Offline Katfish
  • 70 Challenger
« Reply #2 on: November 08, 2008 - 05:35:56 PM »
Any rule of thumb for how much each turn of the allen nead will reduce the advance?
Offline 71chally416
    • The Streetwalker
« Reply #3 on: November 08, 2008 - 06:16:58 PM »
Only the hex-shaped vacuum cannister noses are adjustable with a 3/32" allen wrench, the round ones aren't. Turn it counter-clockwise to reduce advance. Don't know how much it takes. Till it stops pinging??  :dunno:
« Last Edit: November 08, 2008 - 06:19:56 PM by 71chally416 »
« Reply #4 on: November 08, 2008 - 09:33:16 PM »
aprox 1* / turn ,14 turns total
