Resto started!
Author Topic: Resto started!  (Read 71838 times)
Offline mcgheejt
Re: Resto started!
« Reply #15 on: November 12, 2008 - 07:45:47 AM »
Looks like you are having more fun than I would be with such a challenging project.  Keep us posted.
Offline Sean
    • My Cuda Restore
Re: Resto started!
« Reply #16 on: November 16, 2008 - 11:30:26 PM »
It's all about attitude, my friend!  Right now, I'm on a roll and spirits are high!!!  Just the other night, I was coming home from work and the song Panama by Van Halen came over the air waves.  Hearing the drum intro sent shivers down my spine as I realized that will some day be MY CAR making that same rumbling!!!
Speaking of which, made some serious progress over the weekend.  With tremendous help from my brothers, Brad & Matt, tons was done over the course of the weekend.  The following was removed from the car:  front suspension (drums, shocks, A-arms, etc…), tranny, engine, K-member and torsion bars, back seat, seatbelts, interior trim pieces, headliner, package tray, front & rear glass (and cleaned all the adhesive from the window sills), rear side windows & mechanisms,  exterior window trim, trunk lid, tail lights, rear valance panel, rear drive train components (tires, differential, leaf springs, etc…), steering column, and gas tank.  Between the three of us, we probably put in about 48 hours (two days, 8 hours each day, three of us).  Not all of it was easy going.  All the ball joints required heat and persuasion from the 5 lb sledge.  Windows were a pain and time consuming too.  So, all that’s left to remove are the brake and gas lines, steering column braces, rear bumper, gas tank straps, and a few other odds & ends!!! :woohoo:
My brothers worked Friday and Saturday on the car so I fingured the least I could do is take them out to see a local band a catch the tab for their brews!!!  My brothers live 5 hours away and we don't see each other too often.  It was great to spend the time with them doing something we all liked to do! :thumbsup:
Cheers!
Engine out:
Tranny out:
Empty engine bay:
From the rear:
« Last Edit: November 16, 2008 - 11:32:16 PM by Sean »
Offline the_engineers
Re: Resto started!
« Reply #17 on: November 17, 2008 - 04:19:09 PM »
Maybe I missed it...What motor/tranny combo are you planning for?
Looks like great progress.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline cudadave72
  • you motorboatin sob!!!
Re: Resto started!
« Reply #18 on: November 17, 2008 - 05:35:19 PM »
Looks like your coming right along. Looks like a good project!! :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline Sean
    • My Cuda Restore
Re: Resto started!
« Reply #19 on: November 17, 2008 - 05:49:36 PM »
Thanks!   :cooldancing:
the_engineers:  I'm planning on making an AAR clone out of it.  It currently has a 318.  My plan is to put a bored & stroked 360 in it.  I know AARs only came with 340s.  My goal with the car is to make it look as close to an AAR as possible (hence, staying with a small block), but with a little more power.  I want the engine to look stock.  I read an article recently where a guy made a 400+ displacement out of a 360 (in a Duster) and the only thing that didn't look stock was the headers.  I still have to research mroe into how he did it or how I can do something similar.  I'd like to run the cast iron headers if I can.  This is something that I'll have to heavily research and plan.   Additional plans call for a 4-speed tranny too.
Cheers!
Sean
Re: Resto started!
« Reply #20 on: November 17, 2008 - 11:25:39 PM »
Cheers!
Sean
Sean,
There are a lot of people running 400+ inch small blocks on here...71Chally416 comes to mind.  If you're looking for a package, check out Indy Cylinder Head or Hughes.  The 6-pack intake should be pretty easy.
I'm wondering if you'd want to use the carbs for the 440-6.
Brooks
1971 'Cuda 360
Offline Sean
    • My Cuda Restore
Re: Resto started!
« Reply #21 on: November 18, 2008 - 12:13:59 AM »
Sean,
Thanks for the tip on the heads!  I'm not sure what carbs I'd have to use at this point.  I'm not that versed how to design an engine (i.e. what cam, carb cfms I'll need to run, valve sizes, etc...).  I'm reading all I can to educate myself on what I'm going to need to get a a well ballanced motor.
Cheers!
Sean
Offline Sean
    • My Cuda Restore
Offline 73inCanada
Re: Resto started!
« Reply #24 on: November 19, 2008 - 12:46:46 AM »
This is great detail for a guy like myself, you helped me out already...THANKS.....I finally can see what some of my rust should like like when i strip her down one day...when i get the room(when need our garages bigtime in winter) :canada:   GOOD LUCK!
Offline bb71challenger
Re: Resto started!
« Reply #25 on: November 19, 2008 - 01:11:13 AM »
Hey Sean, how are the taillights? I have a decent set but the stainless trim rings are MIA. If you need them they are yours.
*Brett*
Offline Sean
    • My Cuda Restore
Re: Resto started!
« Reply #26 on: November 19, 2008 - 06:12:41 PM »
73inCanada:  You will have a blast with it!  I can understand the need for a garage in Canada!  I'm surprised I haven't caught hell from my wife yet.  Still have lots of parts on HER side of the garage and we're getting frost on the windsheilds.
bb71challenger:  Message sent!   :drunk:
Sean
Offline 74 340 4speed
Re: Resto started!
« Reply #27 on: November 19, 2008 - 08:14:48 PM »
Good luck with it.  Looks like you've got a great start on it. :2thumbs:  You can get those stroked small blocks to run too.  Check out this F.A.S.T. 1970 Challenger T/A.
http://www.fastraces.org/members/fastraces/fastraces.nsf/00000000000000000000000000000000/0a9b33b9ae13f00e8525728f00424bf8!OpenDocument
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline Lunchbox
Re: Resto started!
« Reply #28 on: November 20, 2008 - 12:06:57 AM »
Looks like you have a good start going at it  :2thumbs: keep the pics coming.
Lunch
Offline Sean
    • My Cuda Restore
Re: Resto started!
« Reply #29 on: November 20, 2008 - 12:11:20 AM »
Thanks for the owrds of encouragement guys!!!
Appreciate the link too, 74 340 4speed!!!  Looks like he's already done what I'd like to do (or something very similar).  Book marked that page for future reference!!!
Just wanted to say that you guys and gals have been a great help and that I do appreciate the comments and tech info!!!
Sean
