Author Topic: Mysterious parts from steering column  (Read 1133 times)
Offline noschevys
« on: November 10, 2008 - 09:15:31 PM »
I removed the steering column today so I could refinish the shaft and install a new coupler kit.  When I turned the coulmn upside down, these 2 plastic pins, about 1/8" long, off white with the heads painted black feel out somewhere between the gap in the crush can and housing.  Has anyone seen these before or know what they are?
Offline 73EStroker
Re: Mysterious parts from steering column
« Reply #1 on: November 10, 2008 - 09:46:17 PM »
.............that's where I put my teeth  :roflsmiley:
Barry (Salmon Arm)
« Reply #2 on: November 10, 2008 - 09:54:10 PM »
Kinda looks like pieces of an old horn cap gone bad and seperated from the steel ring. It may have had the horn cap replaced before because it had fell off.
« Reply #3 on: November 12, 2008 - 02:06:45 AM »
could be nylon shear pins from the collapable column too
Offline 71chally416
    • The Streetwalker
« Reply #4 on: November 12, 2008 - 02:08:09 AM »
 :iagree: That's what I thought when I saw them too....
Offline noschevys
« Reply #5 on: November 12, 2008 - 06:48:11 AM »
If so, is that a problem?
Offline farmertan
« Reply #6 on: November 12, 2008 - 11:49:47 AM »
does a schematic of the column exist? everyone should replace there coupler mine broke backing out of my parents drive back in 85, scared the you know what out of me,the night before i was doing 100+ playing w/a camaro,there fairly cheap like 20.00 i think.
73 340 4sp 2nd owner since 85    brett
Offline 71chally416
    • The Streetwalker
« Reply #7 on: November 12, 2008 - 12:18:02 PM »
Only if it comes apart doing 100mph.  :lol:
« Reply #8 on: November 13, 2008 - 03:27:21 AM »
essentially no , the column really cannot move up or down as long as the wheel is bolted on & the roll pin is in the coupler
Offline 71chally416
    • The Streetwalker
« Reply #9 on: November 13, 2008 - 01:50:49 PM »
 :iagree: Chances are somewhere along the line the column was moved just enough to shear the pin heads off. Pull it out and look at it if you're concerned, but I don't know where you can get those pins anymore.
