Author Topic: Can you convert a collum shift to a slap stick?  (Read 2099 times)
beamtallica
« on: April 29, 2004 - 10:49:04 PM »
Offline moparbowhunter
  • MOPARS RULE AND ALL OTHERS DROOOL!!!
Re:Can you convert a collum shift to a slap stick?
« Reply #1 on: April 29, 2004 - 11:02:27 PM »
yes you can, change the column and cut a hole in the floor and mount the slapstick  on the trans hump, put in the counsil and GO!!!!   ;D ;D
70 Barracuda
beamtallica
« Reply #2 on: April 29, 2004 - 11:13:25 PM »
COOL! I have a column. Now all I would need is every thing elas ;D
« Last Edit: April 29, 2004 - 11:13:52 PM by beamtallica »
Offline Burpin Chunks
  • http://mikescuda.net/cuda-challenger/burpin_chunks
« Reply #3 on: April 30, 2004 - 12:23:04 AM »
just make sure you are not doing this to an original numbers matching 1971 Hemi Cuda convertible with 12k original miles stored in a climate control storage for the past 30 years. You wouldnt do that, would you?  >:(
Offline Carlwalski
« Reply #4 on: April 30, 2004 - 02:11:26 AM »
I'm getting it done!!  ;D I've got everything except seats. There should be the precesion holes on the trans tunnel. 3 or 4 holes around the circle shape pretruding from the tunnel towards the pedals, thats where the linkage goes. As far as placing the column either get photos or just "tack" it down and lay the brackets (3), then weld.
You have about 1-2cm of play for the console so it's pretty sweet.  ;)
Hardest part to find will be seats. If it's a 1970 all most impossible.  ;D If your looking for 70 seats looks like we'll be having a bidding match!!  8)
« Last Edit: April 30, 2004 - 02:12:15 AM by NZ 440RT »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline MAXcuda
« Reply #5 on: April 30, 2004 - 08:23:38 AM »
yes, I did it to my car two months ago.  everything went smoothly, no problem.  still gotta get that column changed though.  hopefully will have time to do that in a week or two.  NZ - just curious.. whats the difference between 70 seats and later?
Offline Carlwalski
« Reply #6 on: April 30, 2004 - 02:32:10 PM »
Taller narrower backs. You can just tell. 1972-74 seats are easy to pick out because there not as high and quite plump. LOL!!  ;D
Offline 1973challenger360
« Reply #7 on: April 30, 2004 - 04:32:04 PM »
I have an extra shifter and section of the floor if your interested.
Offline 74chall
  • Mopar or No Car
« Reply #8 on: May 01, 2004 - 02:10:41 PM »
I have two slap stick assemblys. let me know if you need one . Also have a collum for slap stick.
