Author Topic: Torsion bar?  (Read 774 times)
Offline challengerx
Torsion bar?
« on: November 11, 2008 - 09:58:28 AM »
Ok with the help from you guys I have the front susp all rebuilt and ready to bolt back in. Just wondering if the torsion bars should go back into lca sockets so easily. They just slide into the sockets and into the frame correct. Waiting for new boots and clips and I will be bolting the first parts onto the car in 5 yrs. Thanks.
Offline Finoke
Re: Torsion bar?
« Reply #1 on: November 11, 2008 - 10:07:09 AM »
I would like some advice on what to expect too. I'll be doing this in a couple of months.
Re: Torsion bar?
« Reply #2 on: November 11, 2008 - 11:29:18 AM »
It depends , with the lower control arms dropped down I have had some T bars slide right into place , I always put some grease into the sockets before doing this , some I have had to use a hammer to slide them in
Offline challengerx
Re: Torsion bar?
« Reply #3 on: November 11, 2008 - 12:39:04 PM »
Thanks, mine just slid in, now if that fed x guy would show up with the torsion bar boots and clips, I'm dying to bolt something to this car.
Re: Torsion bar?
« Reply #4 on: November 11, 2008 - 01:02:18 PM »
Bad news the boot has to go on Before the bar can go in
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
Re: Torsion bar?
« Reply #5 on: November 11, 2008 - 01:47:00 PM »
Also, at least in my case, the boots were really stiff and VERY hard to get onto the bar.  I recommend grease as others have mentioned, also putting the boot in hot water just before putting them on made a big difference.
You were lucky, my bars needed some persuasion before they would go in.  I still need to get the bars all the way in so I can put the retaining clips in.
Re: Torsion bar?
« Reply #6 on: November 11, 2008 - 01:51:14 PM »
I have used a dull chisel in the slot in the rear of the bar to seat them fully into place
Offline challengerx
Re: Torsion bar?
« Reply #7 on: November 11, 2008 - 03:56:48 PM »
I did realize I could not put it together before I got the boots, which is amazing since I have done just about everything twice so far with the rest of the suspension. Thanks again, I will be posting pic in restoration section soon.
