Author Topic: lug studs.. what do i need?  (Read 1018 times)
Offline black71
  • eph 6:12
« on: November 15, 2008 - 01:28:21 PM »
will be replacing my rotors soon and wantin to get rid of the stupid left threaded lugs studs so i thought i'd replace the fronts now and the rears later when i go through the rear end, so what do i need for the front? i was looking at jegs/summit and dont know exactly what i need  :dunno:
Offline Oldschool
  • Member Since 9-05-06
Re: lug studs.. what do i need?
« Reply #1 on: November 15, 2008 - 01:43:13 PM »
You should be able to go to the dealer or any supplier, (Dorman), and get a set for the right side and install them on the left side.....     :2thumbs:
Ken  --  In Georgia
Offline Changin Gears
« Reply #2 on: November 15, 2008 - 02:04:12 PM »
Rotors usually come with right hands studs already pressed in.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: November 15, 2008 - 02:36:46 PM »
Mine did.
Tom
Tom
Offline black71
  • eph 6:12
« Reply #4 on: November 17, 2008 - 01:20:05 AM »
.... the rotors i just took off are two piece
« Reply #5 on: November 17, 2008 - 01:22:48 AM »
so go to Napa & order studs for the right side of your car
Offline 422STROKER
« Reply #6 on: November 17, 2008 - 01:27:48 PM »
Fine, but did you get original style rotors?  I though all the normal replacements where 1 pc.
Tom
Tom
Offline black71
  • eph 6:12
« Reply #7 on: November 17, 2008 - 10:48:02 PM »
no i haven't gotten them yet, guess i jumped the gun, i have some other stuff to get from jegs so i just thought i'd order the studs with my other stuff, i thought all rotors for my car were two piece
