Help! Lower bearing on steeering column
Author Topic: Help! Lower bearing on steeering column  (Read 1397 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: November 15, 2008 - 06:36:44 PM »
My 1970 'cuda, power steering, slap stick auto does not have a lower bearing on the steering column. Should i add one now that I'm restoring the steering column?
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Help! Lower bearing on steeering column
« Reply #1 on: November 16, 2008 - 02:20:16 AM »
no , it was not supposed to be there , just bolt the column in place under the dash , the lower plate on the floor floats so center the inner shaft & outer  housing & tighten the bolt up
Offline widing'cuda
« Reply #2 on: November 16, 2008 - 08:28:32 AM »
Ok, so it would not help to put one there for better support of the steering wheel? Most other mopars has one...
Offline hemiken
« Reply #3 on: November 16, 2008 - 09:26:06 AM »
What we do hear in Australia is to fit a small strip of felting to the gap, just loosely, just snug enough not to fall out.  this will act as a support in a very minor way but will also keep all debris out of the shaft area itself, felt will hold its place and will not swell to cause any binding at all.      :2thumbs:
Offline LAA66
« Reply #4 on: November 16, 2008 - 09:59:58 AM »
 :iagree: Stops any rattling too.
Offline widing'cuda
« Reply #5 on: November 16, 2008 - 04:40:55 PM »
yeah cause mine do rattle some. So this bearing will not fit: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120219269513
Offline widing'cuda
« Reply #6 on: November 22, 2008 - 09:25:54 AM »
anyeone know?
« Reply #7 on: November 22, 2008 - 10:00:05 AM »
ti was never designed for a brg , there was a nylon sleeve that slides into the end of the housing only
Offline widing'cuda
« Reply #8 on: November 22, 2008 - 10:07:14 AM »
Ok, thanks
Anyone know were I can get the nylon sleeve?
« Reply #9 on: November 22, 2008 - 10:34:25 AM »
Try Mopar first I believe they still have it
Offline widing'cuda
« Reply #10 on: November 22, 2008 - 05:27:08 PM »
Do you know the part No?
Offline widing'cuda
« Reply #11 on: November 22, 2008 - 05:36:41 PM »
Is this one the correct one?
Offline Grancoupe
« Reply #12 on: November 22, 2008 - 06:05:13 PM »
Believe it or not but I had a spare role of electricians tape that was used up the perfect amount to fit the outer dimension. The inner dimension of the role of tape fit the steering shaft perfect. I think I was getting some fumes in through there and was trying to cancel out any possible holes that were letting funes in the car. The thing slid it nice and snug and has been in there for about two years. And from the outside you cant tell what it is.
