pedal assy.
bracket for the pedal assy. goes thru the firewall
pedal push rod...rod from the pedals to the Z-bar
bracket for the z-bar(40.00) needs to be welded to the frame
z-bar(new around 90.00)
adjustment rod--goes from the z-bar to the clutch fork
clutch fork
flywheel
clutch
pressure plate
throwout bearing
pilot bushing or bearing
bell housing
4-speed trans
trans hump
pistol grip shifter
shifter boot
console if wanted
body mods would be
1.putting in the trans hump..cut and weld
2.drill two holes in the firewall for the pedal bracket
3. the bracket for the Z-bar weld it to the frame.
