Author Topic: 70 Speedo reset  (Read 2964 times)
Offline VTMopar
70 Speedo reset
« on: November 18, 2008 - 11:41:22 PM »
Does anyone have pics of their '70 (perhaps 71 also) speedometer -- especially the back side (out of the cluster)     I think I'm missing something in mine related to the re-set shaft) .....       I can't see where the reset set shaft does anything.....
thanks
Vermont MOPAR
VT MOPAR
Offline FY1Cuda
Re: 70 Speedo reset
« Reply #1 on: November 19, 2008 - 10:53:26 PM »
This probably doesn't help, but...
If you're talking about a rallye dash, the reset isn't on the back; it's on the front on the lower right side of the dial.  There is a shaft that pushes in to reset the trip odometer.
If you're talking about a regular, non-rallye dash, there is no trip odometer and thus no reset.
Re: 70 Speedo reset
« Reply #2 on: November 19, 2008 - 11:14:11 PM »
in 70 the reset has a cable it comes through the face beside the guage & curls into the rear of the guage to reset
Re: 70 Speedo reset
« Reply #3 on: November 20, 2008 - 12:11:50 AM »
Do you twist ?  ....seems like I used to twist, not push in.
Re: 70 Speedo reset
« Reply #4 on: November 20, 2008 - 12:55:23 PM »
I can`t remember , I though you pushed & twisted
Offline wally426ci
    • maryland mopars
Re: 70 Speedo reset
« Reply #5 on: November 20, 2008 - 01:25:07 PM »
Are we still talking Speedo's here ?  :roflsmiley:
I couldn't resist.  :bigsmile:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: 70 Speedo reset
« Reply #6 on: November 20, 2008 - 05:55:47 PM »
You push it in. It might take a couple of tries, but the only twisting is done on the clock reset knob.
(Insert sexual jokes below)   :misbehaving:
Offline VTMopar
Re: 70 Speedo reset
« Reply #7 on: November 20, 2008 - 11:04:13 PM »
Yes - it works with a push ;D     I discovered that somehow mine is missing the part that the push rod hits and then resets the odometer...   :swear:    Finding parts for speedos doesn't seem to be very easy......   The clock cable in this 70 rallye guage cluster is also shot -- wonder what the chances of finding one of those might be (I know they sell repops - but......
Thanks for the help
VT MOPAR
VT MOPAR
Offline FY1Cuda
« Last Edit: November 21, 2008 - 07:27:23 PM by FY1Cuda »
Offline VTMopar
Re: 70 Speedo reset
« Reply #9 on: November 22, 2008 - 09:33:22 PM »
Thanks FY1Cuda -- I'm trying to find an original cable and I already have the speedo push rod -- the part I'm trying to find for the speedo is the part the rod pushes and it turns he gear to re-set the odometer to zero (they apparently are quite rare as the resto guys use them when they re-build the speedos).     Perhaps someone has a speedo that is in tough shape but this part is still ok... ?
VT MOPAR
VT MOPAR
Offline FY1 RT SE
Re: 70 Speedo reset
« Reply #10 on: November 24, 2008 - 11:35:36 AM »
thanks
Vermont MOPAR
Offline VTMopar
Re: 70 Speedo reset
« Reply #11 on: November 24, 2008 - 02:32:40 PM »
THAT's IT    Thanks FY! RT SE
It's the round piece with the grooves that the rod fits into and it moves the longer "gear" to reset the odometer.
If there's any chance you want to part with it -- let me know.    Otherwise, wonder if there is a way for me to fabricate something that might work in its place...    :clueless:
Thanks again -- Very helpful.
VT MOPAR
VT MOPAR
Offline VTMopar
Re: 70 Speedo reset
« Reply #12 on: November 24, 2008 - 09:36:15 PM »
Well, I "made" one this afternoon from a 3/8'' bolt and a spring from a bic pen.   I did go through a couple of drill
bits though  :lol2:  But ... it works great!      :bananasmi   :bananasmi
Thanks again for the pics - really helped.
Vermont MOPAR
« Last Edit: November 24, 2008 - 09:38:03 PM by Vermont MOPAR »
VT MOPAR
Offline Glennster
Re: 70 Speedo reset
« Reply #13 on: November 24, 2008 - 10:27:50 PM »
You guys better keep an eye on '' Vermont MOPAR '', I think this guy is a sleeper restoration guy..................................
Nice fix ! ! ! ! !
