Author Topic: tire flat spots  (Read 1439 times)
Offline kslush
tire flat spots
« on: November 19, 2008 - 11:56:19 AM »
OK, so thinking about going with a BFG drag radial tire for the back (275/40/17).  I read on another site that one guy would get flat spots on the tire if the car would sit for more than 1 day at a time with these mounted on it.  Have any of you guys experienced this?  I would assume this would happen to a degree with this soft of a tire, but I also assume they would round back out pretty quickly once you drive a little.  Thanks in advance for the input.
Re: tire flat spots
« Reply #1 on: November 19, 2008 - 01:05:03 PM »
go to www.discounttiredirect.com they have the Nitto 555 Drag Radials for $135
Offline kslush
Re: tire flat spots
« Reply #2 on: November 19, 2008 - 03:58:20 PM »
I prefer a US made tire.
Offline Supercuda
Re: tire flat spots
« Reply #3 on: November 19, 2008 - 06:49:40 PM »
Many tires have a problem with "flatspotting" when allowed to sit for any amount of time, and BFG is one of the worst offenders. It has nothing to do with the compounding of the rubber, but rather with the construction of the carcass. The original belted T/A radial had absolutely HORRENDOUS flatspotting, due to the stiff construction of the belts. It would often take several miles for enough heat to build up in the tire to relieve the issue. Many performance tires (both radial and bias-ply) will do this, and it is less prominent in "regular" tires, due to their less-rigid construction. Even the tires on my Subaru will flatspot when I park it. Remember that, the more heat in the tire when it is parked, the more likely that the tire will flatspot. Long-term storage (more than a week) should still be done with the tires off the ground, because a flat spot can become a permanent annoyance. Plastics and synthetics seem to be the most prone to flatspotting, and steel belts appear to be the least prone to it. I hope this information is useful.
Re: tire flat spots
« Reply #4 on: November 19, 2008 - 11:22:12 PM »
Makes sense except last time I checked BFG is French
Offline resq302
Re: tire flat spots
« Reply #5 on: November 20, 2008 - 08:35:58 AM »
I tend to get "flat spots" in my daily driver 2005 Ford F150 when the weather gets really cold here in NJ.  After a while of driving, it is fine.  Tires are Goodyears.  What I do over the winter with my antiques is to pump up the air in the tires a little more so they are "over inflated" to make them more round to prevent the flat spots.  Seems to have worked for the last 2 years or so.
Offline kslush
Re: tire flat spots
« Reply #6 on: November 20, 2008 - 09:32:30 AM »
That tire is still made in the US....better than nothing.
Offline kslush
Re: tire flat spots
« Reply #7 on: November 24, 2008 - 03:10:08 PM »
Thanks for the good reply.
Offline Supercuda
Re: tire flat spots
« Reply #8 on: November 26, 2008 - 08:01:30 PM »
When I think that some of the knowledge I've gained over the years can be useful, I share. If I don't share it, it can't be passed along. Glad to help.
