Author Topic: Max tire size  (Read 1677 times)
nivvy
Max tire size
« on: May 04, 2004 - 01:43:22 AM »
Does anyone know the max tires you can run with a stock set up and a spring relo kit......also what is the prober backspacing for the rim with each......
Offline GreenFish
Re: Max tire size
« Reply #1 on: September 10, 2004 - 10:44:54 AM »
8pack i got your msg. Ill get that info for you tonight
Re: Max tire size
« Reply #2 on: September 10, 2004 - 12:25:30 PM »
I know a 295/50 will fit without the relocate kit
Offline GreenFish
Re: Max tire size
« Reply #3 on: September 13, 2004 - 02:11:57 PM »
8 pack i sent you a msg with pics of my 28x12.50 MT ET streets on my cuda with no mods
Offline GreenFish
Re: Max tire size
« Reply #4 on: September 13, 2004 - 02:15:55 PM »
8 pack,  I guess the wheels i have are 4 1/2 backspacing.. I use the mopar ralley's in 8 ich.  I also have to use a 1/2 inch spacer because the tires rub on the leaf springs with out it. you could probably not have to use the spacer with an extra 1/2 in of back spacing(or less .. not sure)
