Author Topic: trans leaks.. always  (Read 1449 times)
Offline 71fish
  • Bless you..
    • Ken's 71fish
« on: May 04, 2004 - 03:21:56 PM »
ok.. can't drive the mopar to the shows w/ the trans leaking. Are you guys oputting silicone on w/ the gasket..
feeling a little inadequate.
Trans gasket tips?? is this a problem fopr anyone else?
71fish
71fish - Nobody better than an E-BODY!!
Offline GhettoPop
  • I need a new pair of hookers
Re:trans leaks.. always
« Reply #1 on: May 04, 2004 - 03:53:55 PM »
my 727 has a nice steady leak too, not too bad, a few drops here and there.  upgraded to an 8 quart B&M pan, for some resaon it makes me feel better.
MOPAR 4 LIFE!
« Reply #2 on: May 04, 2004 - 05:25:02 PM »
I use the Felpro rubber gaskets over the cork style
silicone is ok as long as you use a thin coat
Offline 1973challenger360
« Reply #3 on: May 05, 2004 - 04:18:55 PM »
is the o ring on the filler tube leaking ?
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #4 on: May 06, 2004 - 11:18:11 AM »
"is the o ring on the filler tube leaking ? "
No, but I'll check. I did not mention that one of the bolt holes is stripped. I can't believe that one would do that. Also it leaks when running.. idle, park, drive whatever... is that because the viscosity thins sooo much??
It is def leaking from the pan.. i think. and not from where the bolt is stripped.
I wish someone made a steel reeinforced gasket like they do for the valve covers i have.. they are great!!
71fish
