Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Steering shaft coupler
« previous
next »
Print
Pages: [
1
Author
Topic: Steering shaft coupler (Read 700 times)
flores_57
Jr. Member
on:
November 20, 2008 - 07:44:36 PM »
I replaced the power steering box for a manual box. I had to add a coupler to the manual box to adapt to the shaft. Well the coupler on the shaft rubs along the exhaust manifold. Can I replace the coupler with something that would clear the manifold? Thanks in advance
Logged
My lugnuts require more TQ than your ricer produces!!!
Supercuda
Full Member
Re: Steering shaft coupler
Reply #1 on:
November 20, 2008 - 07:49:23 PM »
A die grinder or Dremel with the appropriate carbide burr will achieve the clearance you need. Grind a little on the manifold, and a little on the coupler, until it clears.
Logged
Alaskan_TA
Guest
Reply #2 on:
November 20, 2008 - 08:30:26 PM »
Try loosening the bolts that hold the column to the firewall first, you may be able to push it over far enough to clear & then re-tighten the bolts.
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #3 on:
November 20, 2008 - 08:31:28 PM »
Also look at the engine mounts and how old they are. There is usually some play in the bolt holes for adj as well.
Tom
Logged
Tom
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
