color of 383/4 in a standard Barracuda or Challenger
Author Topic: color of 383/4 in a standard Barracuda or Challenger  (Read 22643 times)
Alaskan_TA
Re: color of 383/4 in a standard Barracuda or Challenger
« Reply #30 on: December 13, 2008 - 11:06:13 PM »
The 1969 model year was the last year for turquoise engine paint. Blue replaced it for 1970.
Offline bb71challenger
« Reply #31 on: December 13, 2008 - 11:10:56 PM »
Thank you Barry, orange it is  :bigsmile:
*Brett*
Offline scf100
  • FAST LANE FOREVER!
« Reply #32 on: December 14, 2008 - 02:19:28 PM »
keep in mind the engine color was related to the engine specifications not the cars......
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
« Reply #33 on: December 14, 2008 - 03:34:52 PM »
The engine bay of my car is not going to be original. I wanted it to look like a regular 383/4 turquoise blue 383. That was before I was informed that turquoise was gone after 1969. I refuse to use the Chrysler blue, I think its fugly as all getout. Therefore I will make it look like a magnum 383 and paint it orange. Its not even going to be a 383 but a dimensionally identical 400 stroker most likely.
*Brett*
Offline Challenger6pak
« Reply #34 on: December 17, 2008 - 09:48:35 PM »
Barry will you help me with this. I do not have my 1970 order sheets anymore. I do have my 71 order sheets. I only find two 383's for 71. I am posting what I have found through several sources. That does not mean it is 100% correct.
1970
VIN L code - 383 2 bbl. Fender Tag E61 color blue
VIN N code - 383 4 bbl 330 horse Fender Tag E62 color blue
VIN N code - 383 4 bbl. 335 horse Fender Tag E63 color orange.
1971
VIN N code - 383 4 bbl. Fender Tag E65 color orange.
Offline EBodysEast
« Reply #35 on: December 24, 2008 - 06:38:48 AM »
Hey guys, pleasure is all mine today. With your permission I'm gonna blow this whole thing wide open over the next few days or even weeks with your help so stayed glued to your seats everyone... I own a '70 Barracuda BH27N0B. It has a 330hp 383 4bbl N code, its automatic, engine color is blue, has a/c and is a non ECS non Cal emmisions. Flat hood, 383 four barrel emblems under the Barracuda script. I do share the common interest in this exact topic & sniffin' around & just caught wind of it.
There were three versions of 383 intended for the U.S. market in '70. Replacement short block 383's exported to Canada had a unique part numbers & appear to have had a lower compression ratio. There was the 1) L Code E61-290hp 2bbl - 2) N Code E63-330hp 4bbl and 3) the N Code E63-335hp 4bbl HP. Having either an L or an N in the 5th digit of the VIN for the dash pad, door label, engine VIN pad, trans pad, cowl, rad support, etc. to match all other documents that remain with that car are how these E Bodys can be documented & examinedd for levels of authenticity.
E61 (2bbl) and E63 (4bbl) were merely the 'sales codes' mainly designated to Mopar dealership owners & their salesmen there at the dealer to order their E Body customers a 383 in either a 2 or 4bbl. One of these two sales codes will be found on 1) the original bill of sale from the dealer/factory invoice/window sticker 2) the fender tag and 3) the bcs. Challenger6pack, what's up brother, :2thumbs: there may be no such thing as an E62 330hp 4bbl from where my searches had taken me till now & may be safe to take it off your list above.
Consider that Supercuda is not the original owner of the L code 4bbl he mentioned that may easily have had its original 2bbl intake manifold swapped to a 4bbl some time after it left the factory. No offense Supercuda.  :2thumbs: I'd like to hear more. His engine was also painted blue you said and remember that there were no orange 2bbls, 2bbl's were all blue. I know of one Barracuda L code in a j-yard right now. The blue 383 2bbl block and heads are still there preserved, but oddly or not it does have a 4bbl intake on top. Whatever 4bbl carb it once had is MIA, it's been in that j-yard for sale the past 20 years. I checked and the intake is not the correct '70 666 intake and the date on it is a 1969 part number. The final proof are the 2bbl part numbers cast plain as day into the side of the block. Easy to see how it was simply a performance swap done for the instant hp gains when racing against Chevy's & Ford's back in the day. Keep reading and you'll see how you could have verified exactly what it is your friend had. I'll have to check if there is a cast crank mark stamped into the pad to further document it as being a 2bbl L code and no more than that. This car simply had 383 emblems directly beneath the Barracuda fender scripts. Not 383 four barrel scripts like you would expect to find on a 4bbl car. The factory drilled emblem mounting holes in the 2 barrel fenders are different dimensions/locations than the holes drilled for four barrel fenders because the emblems do not share the same stud placements on the rear. Did your friend's car have 383 emblems on the fenders. Could be a clue.
All three versions of the 383 mentioned above could be ordered in a Barracuda (not a 'Cuda) & in a Challenger V8 (not an R/T.) I can tell you this, what you guys are missing is very valuable if you are to ever learn the truth here. While the E61 & E63 codes and the L & N codes are easy to quickly find - there are one set of numbers, 3 to be exact, and you'll only find those 3 numbers in one place. You guessed it. The bcs. And I'm gonna give you those bcs codes right now, given kindly to me courtesy of my mentors on another site.
084 = 383/4, manual, a/c, painted blue, 330hp
085 = 383/4, auto, no a/c, blue, 330 hp
086 = 383/4, auto, a/c, blue, 330 hp
087 = 383/4, manual, no a/c, orange, 335 hp
088 = 383/4, auto, no a/c, orange, 335 hp
089 = 383/4, auto a/c, orange, 335 hp
These were the assembly line codes for, you guessed it, the assembly line workers in charge of putting the predetermined engines into these cars, we see there were six possibilities. In some documented cases, these 3 engine bcs numbers were found to be written on a valve cover by a worker to quickly help them better visually distinguish from all the others.
If you have a F series/1970 bcs the 3 engine numbers are found on line 4 - in the engine box. The 3 numbers between the 2 vac fitting numbers and the 2 carb numbers. Or commonly there are cases where '70's were printed on left over E series/1969 bcs's. In that case you can still go to line four on a '69 sheet and find the numbers - they still follow where the first 2 vac fitting numbers would be on a '70 bcs.
If, and only if there is an original bcs with these 3 numbers still legible, only then can you use the breakdowns above. Consider that some cars didn't get a BCS (L.A. bcs 's are uncommon but do exist) that some are missing, that some that do remain are torn/tatered & missing pieces, while others even came with one that was not for that same car. The more original bcs's that are deciphered, the more that any one particular pattern can start to emerge. The more we'll learn. I have 2 original bcs's for my car. The engine code for my BH27NOB is 086. We see that an 086 code 383/4 is not an HP & was painted blue just like the chart states and just as Barry's chart from earlier explains. Now then, my block does not have an HP stamp on the pad near distributor, no HP stamp anywhere. This offers more evidence of why I believe it to be a 330hp version. A block that has an HP stamp somewhere on it should in most all cases be accepted as being painted orange.
The next thing to discuss would be carbs. See list below. The 330hp blue engines I've researched the past few months had a Carter, while the 335hp orange engines all have a Holley. These were documented by bcs deciphering and not here say from someone's memory of one back in the day. What you guys as members here that own any of the N codes and L codes will have to start is to produce some documentation and pics for the rest of us. My research is on going and all is up for debate in a forum such as this is. I'll close for now with this carb list created by a highly knowledgable friend - file it with the engine codes guys 'cause its basically gold and my present to the forum here. Happy holidays everyone!  :drunk:
383 manual - E & B-body - with ECS (N95).......... orange HP engine 335hp
---------- Holley R4217-A ----------part number 3418 537 on b'cast 37
383 manual - E & B-body - w/o ECS................... orange HP engine 335hp engine on b'cast 084 wA/C & 087---------------- Holley R4367-A ----------part number 3418 536 on b'cast 36
383 Manual - E & B-body - w/o ECS & with "fresh air" (N96). orange HP engine 335hp
---------- Holley R4736-1A ----------part number 3512 964 on b'cast 64
383 Manual - E & B-body - with ECS (N95) & with "fresh air" (N96). orange HP engine 335hp-------------------------- Holley R4738-1A ----------part number 3512 974 on b'cast 74
383 automatic - E, C & B-body - w/o A/C & w/o ECS............. blue engine 330hp
---------- Carter 4736S ----------part number 3418 538 on b'cast 38
383 automatic - E, C & B-body - with A/C (H51) & w/o ECS..... blue engine 330hp
---------- Carter 4732S ----------part number 3418 540 on b'cast 40
383 automatic - E, C & B-body - with ECS (N95)................... blue engine 330hp
---------- Carter 4734S ----------part number 3418 541 on b'cast 41
383 automatic - E & B-body - w/o A/C & w/o ECS............... orange HP engine 335hp engine on b'cast 088----------- Holley R4368-A ----------part number 3418 542 on b'cast 42
383 automatic - E & B-body - w/o A/C & with "fresh air" (N96). orange HP engine 335hp engine on b'cast 088---------- Holley R4737-1A ----------part number 3512 965 on b'cast 65
383 automatic - E & B-body - with ECS (N95)..................... orange HP engine 335hp
---------- Holley R4218-A ----------part number 3418 543 on b'cast 43
383 automatic - E & B-body - with A/C (H51) & w/o ECS....... orange HP engine 335hp engine on b'cast 089-- Holley R4369-A --part number 3418 562 on b'cast 62
383 Automatic - E & B-body - with ECS (N95) & with "fresh air" (N96). orange HP engine 335hp------ Holley R4739-1A ----------part number 3512 975 on b'cast 75
« Last Edit: December 24, 2008 - 06:42:25 AM by EBodysEast »
« Reply #36 on: December 24, 2008 - 09:04:51 AM »
Great information. Thanks. So basically if you do not have  BCS there is no way to know if the N-code E-63 stood for 330 or 335 horse 383. Correct?
« Reply #37 on: December 24, 2008 - 09:36:38 AM »
BCS=build sheet?
*Brett*
Offline moparnut
    • My Photo's
« Reply #38 on: December 24, 2008 - 11:09:43 AM »
It looks like in 1970 the orange N-code 383 was the only 383 4 bbl. in the Ebody. A blue 383 4 bbl. motor would be for other car lines. Which would make orange the answer for this thread.
My numbers 70 GC has a turquios 383-4(330 horse) and the vin is bp23NOE, the car was untouched when i got it and as numbers matching as you can get.
Knowing Chrysler, im sure the only difference between the HP and NOn hp 383 would be the color, carb and windage tray(IM SURE EVEN THE CAM WAS THE SAME). Im not sure if mine has a windage tray in it since i havent had the engine apart. Its stored and i built a non numbers 383 to have fun with so i dont blow up the original.
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline moparnut
    • My Photo's
« Reply #39 on: December 24, 2008 - 11:46:46 AM »
1970
1971
My 70 GC BPNOE 383-4 has E63 on the fender tag and engine is blue
« Reply #40 on: December 24, 2008 - 01:54:32 PM »
BCS=build sheet?
Yes. AKA Broad Cast Sheet
Moparnut, There were quite a few differences in the 330 and 335 motor. The main differences were to make the 335 more heavy duty not more powerful. I have a list for 1971. I'll try to get it posted over the Holiday.
« Last Edit: December 24, 2008 - 01:58:34 PM by Challenger6pak »
Offline EBodysEast
« Reply #41 on: December 24, 2008 - 03:23:41 PM »
One would think it impossible - only, that's what we have kept all of our survivors around for, and why we decipher those bcs's that remain. Its why we'll need to get any owners here to provide us their BCS info and we'll start to learn more about what the assembly 'matrix' was back then.
Here is one perfect example of what I mean, it's not yet known why and its good stuff too - especially if you like mysteries.
Here is a BCS - currently for sale on Ebay (Sylvain) - for a 1970 'Cuda 383 HT - Scheduled Production Date (SPD) is a very early: A02 or Oct 02,1969.
Notice it is for a non A/C car, also notice it is coded 085 for a 330 hp blue painted engine with a 38 Carter carb. Finding a 'Cuda or Chally R/T with an 085/38 blue engine is probably a very hard thing to do...even back in the day when new. Now compare it to a near identical BCS for a '70 'Cuda 383 SPD (A13/Oct 13) of same plant & just 11 days later - BCS is for sale on Ebay as well. It has 088/42 (Holley) codes for an orange HP 335hp engine.
Why did one get coded & built different then the other. They' re both auto and non A/C?!?! The answer may be there somewhere in the BCS. Fresh air hood vs non fresh air hood / ECS vs non ECS / something is there that may tell or offer even a clue. Either way, here may be proof positive of a performance model getting a blue engine in at least this one case.
« Last Edit: January 08, 2009 - 02:53:09 AM by EBodysEast »
Offline EBodysEast
« Reply #42 on: December 24, 2008 - 04:47:26 PM »
This BCS below (for the second 'Cuda) is also like one of the bcs's I mentioned above that was a '70 model's info printed out on a left-over 1969 BCS - You may need a '70 BCS to follow along in decoding the entire thing. Still - for our purpose here for now just go to line four and its there, the 3 digit 088 engine number code and its 2 digit carb code right of them.
Anybody have any clues as to why two nearly identical 'Cudas built within a very short time of each other at the same plant (unknown if same shift) still with a slim chance that alot of the same people put them both together, why did they recieve two different motors from one another. The answer may be in there so give them a good once over.
With enough bcs comparisons and owners coming together on this we can figure this out to some degree better. Here is a collection of on going bcs data that probably didn't happen over night so lets respect the source as I do. If you guys here can add something to his bcs data, maybe Dan will catch wind of it.  :2thumbs:
4-speed with A/C
JS E63 D21 eng-084 carb-36
4-speed
BS E63 D21 eng-087 carb-36
BP E63 D21 eng-087 carb-36
JS E63 D21 eng-087 carb-36
JH E63 D21 eng-087 carb-36
RP E63 D21 eng-087 carb-36
XH E63 D21 eng-087 carb-36
automatic no a/c
BS E63 D32 eng-088 carb-42
JS E63 D32 eng-088 carb-42
RM E63 D32 eng-088 carb-42
WM E63 D32 eng-088 carb-42
XP E63 D32 eng-088 carb-42
JH27NOB E63 D32 eng-085 carb-38
automatic with N96
RM E63 D32 eng-088 carb-65
automatic with A/C
BS E63 D32 eng-089 carb-62
JS E63 D32 eng-089 carb-62
RM E63 D32 eng-089 carb-62
XP E63 D32 eng-089 carb-62
I contacted the owner of this one for bcs info recently for sale on ebay:
BS27NOB - 4 spd - 084/36
Uh huh, its another 084/36 just like the Challenger R/T up there all alone and by it self. Not any more! So this one's for Dan if he wants to add to that fine little list made for us. Consider that the engine in that 'Cuda conv above is orange. The engine codes above tell us that the 084 engine should be blue and 330hp...only it really isn't now is it. Look at it closely if you can. The carb code is a Holley. There were no Carter carbs listed for a 4-speed in the 70-71 parts catalog. None. So it is Dan's belief and now mine too that the 084 is really a 087. Compare all the bcs info from all of those 087 engines to the 2 084's. They all have a 36 Holley in common.
Where are these engine combos on the EC list & what are their engine assembly codes? Why were they ommited. Nobody knows...yet. Time will tell.
0?? = 383/4, manual, no a/c, painted blue, 330hp
0?? = 383/4, manual, a/c, painted orange, 335hp
Sleepychallenger has an N code motor maybe he'll share a little more about, while  Challenger6pack has a 4 speed.
FY1443433 has a 4 speed and a/c orange engine and would be interesing to know what its original engine code is. Becasue if we look at the EC list it is misleading in one small way - there isn't a code there for a 335hp 4 speed with a/c orange 383. Look again. Chances are high his EC is (if he has a bcs to verify) or was (if not) probably a 084 code on the bcs is the main point to stress here. An 087 in disguise if you will. It would seem logical to present then that there were no blue 383 4 speeds with air and only 330hp.
« Last Edit: December 24, 2008 - 11:17:56 PM by EBodysEast »
« Reply #43 on: December 24, 2008 - 05:13:54 PM »
My car does not have the original motor or BCS. The original seats were swaped for better ones and the 383 was replaced with a New Yorker 440 back in the 80's. The second owner didn't care about originality since it was a 383 non R/T car. It was being used for parts when I got it. It is a shell now. I have been collecting what it needs over the years. I am lucky the fender tag still is on it.
« Reply #44 on: December 24, 2008 - 06:11:07 PM »
I have never found a build sheet on any of my cars. I swear I must have gotten to them after the tweakers got through with them. My 71 may or may not have had it, when I bought it they guy gave me a big manilla folder with a bunch of papers in it which I misplaced over the years. I know they took all the interior out when they had it painted blue. They painted everything blue. even part of the dash frame is blue  :eek4: Around here if you bought a car with the data plate AND a build sheet you could consider yourself a lotto winner.
*Brett*
