Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
A/C question
« previous
next »
Print
Pages: [
1
2
Author
Topic: A/C question (Read 2709 times)
roy282
Jr. Member
A/C question
on:
November 24, 2008 - 04:23:32 PM »
Would someone here be able to tell me if the A/C parts (compressor, condenser, valves, lines and brackets)on a 70 Plymouth fury with 318 are the same as E bodies? If so what's the difference with a big block E body?? Thanks Rob
Last Edit: November 24, 2008 - 05:28:16 PM by roy282
Logged
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Chryco Psycho
Administrator
C-C.com Guru
Re: A/C question
Reply #1 on:
November 25, 2008 - 02:37:23 AM »
to my knowledge they would be nowhere close to fitting , the 70 Fury is a C body using a totally different body mount system & engine compartment shape some fo the components would obviously work some of the hoses May be fitted to the E body , condenser could probably used by making some custom mounting tabs
Logged
roy282
Jr. Member
Re: A/C question
Reply #2 on:
November 26, 2008 - 05:02:07 PM »
Thanks for the reply but Does anybody know if there's a way to tell what year an a/c compressor is from and also an a/c air drier. Thanks!
Logged
bb71challenger
Sr. Resident
Re: A/C question
Reply #3 on:
November 26, 2008 - 07:34:58 PM »
The individual components would probably be the same but stuff like the hoses and condensor would most likely be different.
Logged
*Brett*
roy282
Jr. Member
Re: A/C question
Reply #4 on:
November 27, 2008 - 06:48:30 PM »
would someone here be able to clear up 2 more Questions on E Body A/C
1: Did any E Bodies with the 22" rad come with factor A/C?
2: Almost sure that they did not but would a factory size A/C condenser fit the E Body with the 22" rad??
Thanks for your time and Comments!! Rob
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: A/C question
Reply #5 on:
November 27, 2008 - 06:54:37 PM »
to my knowledge no but I am not an expert , I believe that when you order A/C you got the HD cooling / 26 " rad , there is no reason why the condenser will not fit in front of the 22" rad the opening is the same size
Logged
roy282
Jr. Member
Re: A/C question
Reply #6 on:
November 27, 2008 - 07:47:06 PM »
Thanks Chryco thought that was the case the reason why I'm asking is that I'm trying to set up my gran coupe with some a/c Chrysler dealership issued . this is the airtemp unite I have and restored .Here's some pics of what I have already from a 1970 plymouth fury
Logged
bb71challenger
Sr. Resident
Re: A/C question
Reply #7 on:
November 27, 2008 - 11:39:40 PM »
I have never had good luck with compressors that have sat idle for years. The head gaskets usually leak. While you have it off you might want to get some new gaskets on it. You get the bonus of checking out the reeds and such while you are in there.
Logged
*Brett*
roy282
Jr. Member
Re: A/C question
Reply #8 on:
November 29, 2008 - 12:25:57 AM »
Thanks for the advice on doing the head gaskets bb71challenger.Rob
Logged
Lunchbox
Sr. Member
Re: A/C question
Reply #9 on:
November 29, 2008 - 02:58:13 AM »
Small block and big block compressor brackets are different.
Lunch
Logged
bb71challenger
Sr. Resident
Re: A/C question
Reply #10 on:
November 29, 2008 - 11:05:43 AM »
Hey, a buddy of mine has a 72 or 73 340 rallye Challenger that had air conditioning added from the dealership. I know somd things are different compared to a factory air car like the holes for the lines and stuff like that. I can try to snap a few pics for you and post them if you want me to. The only monkey in the wrench might be that he is getting the roof replaced. Earlier this year I cut a roof off of one of my parts cars for him because his car was parked under a window unit refrigerated air system and it totally rotted the roof out. Let me know if you want some under hood and cabin pics. I know the system has been taken out to some degree but the holes in the firewall and I think the underdash unit are still in place.
Logged
*Brett*
roy282
Jr. Member
Re: A/C question
Reply #11 on:
November 29, 2008 - 11:17:04 PM »
That would be very helpful bb71challenger if you can get some clear pics and totally appreciated !!! to bad about your friends car but hopefully it's getting it's make over. What should I be looking for once the head is off to see if the a/c compressor is good?? and any other thing that make them run.Thanks Lunchbox for mentioning the brackets I have both big block/small. Thanks EH!!! Rob
Logged
roy282
Jr. Member
Re: A/C question
Reply #12 on:
November 30, 2008 - 11:39:30 AM »
Here are some more pics of the rest of the a/c lines .Would any body know what the pressure the a/c lines/ canister should be able to hold??Thanks
Logged
bb71challenger
Sr. Resident
Re: A/C question
Reply #13 on:
November 30, 2008 - 11:44:48 AM »
High pressure side (small diameter) has somewhere around 220-250 psi. if I remember right. I know anything ove 300 is too much. Been a while since I charged a system so I am sure I am not spot on but you get the idea.
Logged
*Brett*
roy282
Jr. Member
Re: A/C question
Reply #14 on:
November 30, 2008 - 12:32:19 PM »
Thanks for the info on the lines bb71challenger Could some tell me what I should be looking for in a a/c compressor resto?? beside knew head gaskets.Thanks
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
A/C question
