Author Topic: Removing a vinyl top and glue  (Read 988 times)
Offline mopar340
« on: November 25, 2008 - 10:03:47 AM »
What is the best way to remove the vinyl top and the glue.  Plus will it look good if i leave the lower trim on and just paint the top.
Thanks
Offline AMXguy
Re: Removing a vinyl top and glue
« Reply #1 on: November 25, 2008 - 10:38:36 AM »
Most of the time you can just pull the top off, getting the glue off is tougher. I tried a bunch of solvents with no luck so I just set my DA to grind and buffed it off, it plugs the paper up but it worked.
 Myself I think a painted top would look cheezy, I'd either replace the vinyl or fill the trim holes and paint it the same as the car.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #2 on: November 25, 2008 - 07:58:20 PM »
   Painted tops can look good...some came from the factory, ck this thread
 http://www.cuda-challenger.com/cc/index.php?topic=43831.0
 New vinyl is not that expensive just a little over $100.... You can install yourself with some patience.... http://www.moparmusclemagazine.com/howto/25738_horse_skinning/index.html
 Not having removed mine yet I cannot recomend a solvent but I wonder if 3M adhesive remover would do the trick... http://www.tcpglobal.com/autobodydepot/itemdetail.aspx?itemno=MMM+8908
« Last Edit: November 25, 2008 - 08:04:30 PM by bullitt99 »
Offline cudax34me
« Reply #3 on: November 25, 2008 - 08:21:54 PM »
just a note...if you are talking about a factory top there is no paint under it.sprayed up the A pillar,C pillars.
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #4 on: November 25, 2008 - 09:10:00 PM »
Removed mine exactly as AMX guy did - using the DA on gind. There no paint as was alos said, so it gets to the metal quickly.
