Author Topic: K-member cluelessness  (Read 3386 times)
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« on: November 26, 2008 - 10:08:19 AM »
Can a small block be bolted onto a big block K-member?  :clueless:
If so, what are the special requirements if any.
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Re: K-member cluelessness
« Reply #1 on: November 26, 2008 - 10:12:59 AM »
Yes they essentually used the same K from the factory , all you need is the correct mount to do this , the later small blocks used the spool mounts , all E bodys  used the sandwhich type
Offline JoltinJoe
« Reply #2 on: November 26, 2008 - 10:18:26 AM »
MAN THAT WAS FAST!  Is your ride as fast as you?!?!
So as I understand ya, I can just go ahead and drop a 440 onto my factory 318 K-member?
« Reply #3 on: November 26, 2008 - 10:19:46 AM »
YES & Yes  :2thumbs:
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: November 26, 2008 - 10:36:21 AM »
 :iagree: I've done it twice so far. Dropping 440 6 packs in 318 barracudas, not problems. Just need the correct brackets.
1996 Dodge Viper GTS Coupe
Offline JoltinJoe
« Reply #5 on: November 26, 2008 - 04:36:05 PM »
Well why would someone try to sell a big block K-member?  Just to make the car seem like an original big block car?
Offline 72hemi
« Reply #6 on: November 26, 2008 - 04:44:49 PM »
In general I think it's one of those things where people are trying to get more money for their parts. There are some big block K members that are different and have a skid plate on the bottom of them, and then of course there is the hemi K member which has different mounts.
Offline ChallengerGary
    • Challenger Gary
« Reply #7 on: November 26, 2008 - 08:57:40 PM »
Because as PT Barnum once said, "There's a sucker born every minute."
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
« Reply #8 on: November 26, 2008 - 11:54:07 PM »
the big difference as stated above was the skid plate top protect the deeper oil pan
 there is also a Lot of confusion / misinformation on the need for a different K frame as some years & body styles  do need a different K to install a big block
Offline JoltinJoe
« Reply #9 on: November 27, 2008 - 02:24:49 AM »
Now we getting somewhere!  Do any of the '70-4 e-bodies need a different K to install a big block?
Thanks, CP!
Offline larry4406
« Reply #10 on: November 27, 2008 - 06:29:27 AM »
My 72 cuda had a 340 originally.  It has had a '70 440 in it as well as a '71 383 using the big block mounts.  K frame received it fine.
Offline 72hemi
« Reply #11 on: November 27, 2008 - 06:33:35 AM »
My brothers 73 challenger accepted a 440 with no issue.
Offline Roppa440
« Reply #12 on: November 27, 2008 - 07:01:22 AM »
Thanks, CP!
Yes. The 6 cylinder powered cars have a different K-frame. But as you have already been told the V8 K-frames on E-Body cars will work for any V8.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
« Reply #13 on: November 27, 2008 - 10:47:21 AM »
Thanks, CP!
no all E bodys will swap
 the 73-up B body used a floating K frame which requires a different K , the A body used to have a specific Big block K as well but we found out the production K from a certain few years is identical & also doesn`t need to be swapped until you get into later 73 & up K frames with spool mounts & now with Schumaker making differnt swap mount kits a lot of engines can mow be swapped onto Kframes that were not possible before
