Author Topic: 71-74 E-body floorshift steering column housing  (Read 731 times)
Offline WINGNUT426
« on: November 27, 2008 - 01:03:49 PM »
Converting your 71-4 E-body to floorshift?  This empty steering column will take your shaft, turnsignal switch, Ign. switch etc. from your current column. $60 plus shipping. Thanks for this free ad! petev8@webtv.net
« Last Edit: November 28, 2008 - 05:50:31 PM by AprilsPink72Cuda »
Pete Veight
Bridgewater Ct.
petev8@webtv.net
Offline 422STROKER
  • Member Since 6/3/06
Re: 71-74 E-body floorshift steering column housing
« Reply #1 on: November 27, 2008 - 01:10:34 PM »
I'm assuming a 70 is different somehow?
Tom
Tom
Offline WINGNUT426
« Reply #2 on: November 27, 2008 - 04:26:42 PM »
The 71-74 has a "clicker" you have to push down to remove the key.
The 70 does not have a clicker, but the housing twists to remove the key. I DO have the 3 pieces to make a 70 floor shift column out of column with the shifter. $50 plus ship. E-mail me direct if you are interested.
                               Pete
Pete Veight
Bridgewater Ct.
petev8@webtv.net
