Author Topic: Jack stand placement  (Read 1611 times)
Offline 71bigblock
    • Steve's Mopars
« on: November 28, 2008 - 10:25:23 AM »
Hey guys, will be putting my car on jackstands here pretty quick.  Question is, I have four, where should they be placed?  Just wondering if one place is better than the other.  Thanks.
Re: Jack stand placement
« Reply #1 on: November 28, 2008 - 11:19:32 AM »
I usually go underr the front leaf spring hanger & under the T bar crossmember wherre the frame rail meets it
Offline 71bigblock
    • Steve's Mopars
« Reply #2 on: November 29, 2008 - 12:20:26 PM »
Okay so actually on the t bar crossmember?  That will give it an even load all winter?  Thanks CP.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: November 29, 2008 - 12:42:56 PM »
Maybe for the winter I would do the rear axles and the front control arms?
Tom
Tom
Offline 71bigblock
    • Steve's Mopars
« Reply #4 on: November 29, 2008 - 01:23:45 PM »
Tom
Right Tom, but I want the load off of the suspension, and about the same weight on each stand, to distribute the weight.   :popcorn:
« Reply #5 on: November 29, 2008 - 03:37:44 PM »
So you want all your shocks maxed out and to put stress on the ball joint angles :clueless:  It also puts stress on the equalizer bushhings and other pieces when it just dangles
« Reply #6 on: September 21, 2009 - 12:08:38 PM »
I was just raising my car up in preparation for changing the motor mounts. With a 440 in the nose there is obviously a lot of weight up there. The frame can handle that kind of cantilevering?
« Reply #7 on: September 21, 2009 - 12:20:05 PM »
the torque boxes are right under the door hinges , that is where i place the stands
