Author Topic: Inspecting K Member  (Read 868 times)
Offline challengermaniac
Inspecting K Member
« on: November 29, 2008 - 01:23:27 PM »
Hey guys,
I'm getting ready to check out a 70 Challenger and one thing for certain is I don't want it if it has a bad K member.  Other than test driving to get a feel for the steering (to pick up on noise and odd vibrations), is there a way to check out a K member for damage by crawling under the vehicle?
Thanks, Charlie
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Re: Inspecting K Member
« Reply #1 on: November 29, 2008 - 03:57:26 PM »
just visual stuuf like the bottom being scarred or dented , the weld quality was usually poor around the mounts ,sometimes the tubes for the lower control arm will break out  but generally they are indestructable & do not cause a problem
« Reply #2 on: November 29, 2008 - 04:59:31 PM »
Also, a k member is real easy to replace. Don't let that one inexpensive issue hold you back. They are usually under 100 bucks for most of them. Hemi and skid plate one with a badge are more of course
Offline Beck
    • BECK KUSTOMS
« Reply #3 on: December 01, 2008 - 05:00:09 PM »
don't mean to hijack the thread, but the k member on my 318 cuda has the skid plate.
i'd read that this was only on hemi k members...
is there any other way to tell if mine is a hemi k member or has just had a skid plate welded on.
the skid plate on my k looks just like the pics i have seen of the hemi ones...
cheers,
aaron
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: December 01, 2008 - 05:08:55 PM »
You could get skid plates on other K members as well (like 440 6 pack cars). A 318 won't mount into a hemi k member because of how different the mounts are.
1996 Dodge Viper GTS Coupe
« Reply #5 on: December 01, 2008 - 06:18:43 PM »
It was probably from a 440-6 car.
« Reply #6 on: December 02, 2008 - 01:13:20 AM »
the 440 Hp would have the deep pan & skid plate as well
