Author Topic: 72 cuda tail lamp hardware  (Read 1032 times)
Offline Jim
« on: December 01, 2008 - 12:52:35 PM »
I'm trying to install the tail lamps on my 72. Unfortunately, I can't find the attaching hardware.
The car pretty much came to me in boxes, so I'm not even sure what I'm looking for.
I'm guessing there are some t-bolts and speed nuts that hold the lamps on. I found what I believe are the nuts, but no t-bolts.
A pic would be a great help.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline Travis72
Re: 72 cuda tail lamp hardware
« Reply #1 on: December 04, 2008 - 12:52:23 AM »
Here's a picture of the studs in the tail panel.  The nuts were a cap type shape (no hole).  I don't have a pic handy, but could take one tomorrow if you need it.
Travis
72 Cuda
Offline Jim
« Reply #2 on: December 04, 2008 - 01:21:45 PM »
My car has keyhole-shaped holes where you have studs. I assumed some sort of t-bolt dropped into the holes.
Yours look welded in. :dunno: :clueless:
-Jim
Offline Travis72
« Reply #3 on: December 05, 2008 - 11:51:11 AM »
Here's some better pictures.  The studs are not welded in, but fit through the hole.  The metal on the front helps hold them in place.  Also here some pictures of the nuts as well.  If you want to see the higher resolution pictures, just send me a PM.
Travis
72 Cuda
Offline NorthWestcuda
« Reply #4 on: December 05, 2008 - 11:58:28 AM »
I pulled this picture off the R/T specialties website.  This is what your looking for.
Jim
73 Cuda
1973 Cuda, 440 engine
1972 Chevy 4x4 PU stepside
2003 Ford F-350 Diesel
Offline Jim
« Reply #5 on: December 05, 2008 - 01:27:55 PM »
 :worshippy :2thumbs:
THANKS!
-Jim
Offline Jim
« Reply #6 on: December 06, 2008 - 07:48:59 PM »
Jim
73 Cuda
Where did you find that? I'm scouring the website and I can't find it.
-Jim
Offline Jim
« Reply #7 on: December 06, 2008 - 07:58:01 PM »
Nevermind. Found it. Search feature could use some help on that site.
http://www.rtspecialties.net/proddetail.asp?prod=1000341
Holy Crap... $39! :22yikes:
-Jim
