Author Topic: Recommended plugs with MSD 6  (Read 1302 times)
Offline Challenger_7
« on: December 02, 2008 - 10:40:51 AM »
Hi all
I recently upgraded my 71 Chally's 400 engine ignition from the standard to an MSD 6 with the flame thrower coil. Someone suggested I should now widen the gap of the normal spark plugs to 100, or better still use different plugs all together.
Any advice on this?
Cheers
71 Chally Conv 383 Magnum Manual - Hurst
71 Chally Auto 383 Magnum R/T 100% Orig
71 Chally Auto 400
70 Chally Auto small block
72 Charger SE Manual - Hurst
73 Plymouth Satellite "Sebring Plus" 100% Orig
Others: http://www.cardomain.com/id/Challenger_7
Offline GoodysGotaCuda
Re: Recommended plugs with MSD 6
« Reply #1 on: December 02, 2008 - 10:49:37 AM »
I  would not increase the gap to that size. If you look in the MSD manual it will give you a recommended gap spec, dependant on compression ratio. I run .045" with my little engine and MSD. .100 is way too wide, will probably kill your coil pretty fast as well. In my opinion..
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: December 02, 2008 - 11:10:34 AM »
I would use the same Champ RJ12YC plugs gapped at .045 instead of .035, more then .045 is hard on the coil & wires
Offline Oldschool
  • Member Since 9-05-06
« Reply #3 on: December 02, 2008 - 11:15:25 AM »
I run the stock Champion N9YC's in the beast (Hemi).  I split the difference and run the gap @ .45.  Never had a problem....    :thumbsup:
Ken  --  In Georgia
« Reply #4 on: December 03, 2008 - 01:09:59 AM »
Thank you all for the replies. Just to confirm, I believe you are saying .045 inches right?
When I said 100 I meant in cm i.e. 0.100cm as normally they come gapped at 0.070cm.
Anyway, not quite sure of the equivalent of one to the other but 45 thou (inches) is what I will do.
Thanks
71 Chally Auto 400
