Author Topic: Auto Rust Technicians subframe connectors  (Read 10874 times)
Offline Chlngrcrzy
Re: Auto Rust Technicians subframe connectors
« Reply #15 on: December 05, 2008 - 09:37:31 PM »
Nice :2thumbs:
Offline 71chally416
    • The Streetwalker
« Reply #16 on: December 05, 2008 - 09:47:36 PM »
I agree the floor pan does not make a sound structural element. The box tubing is better. Better yet is to cut the floor and use rectangular box tube welded to the floor. That also gives a great mounting point for a roll bar main hoop which should always be tied to the frame. If you're not using a cage the box tube is fine.
Offline 30below
« Reply #17 on: December 06, 2008 - 09:59:53 AM »
No problem Dave.The bill is Dec 27/07
Offline A R T
  • Looks like some one needs to be frisked....
    • Auto Rust Technicians/Safe-T-Cap
« Reply #18 on: December 08, 2008 - 12:54:49 PM »
I want the double discount.
Tom :stirpot:
By tdavist, shot with DSC-W55 at 2008-08-20
UUU-MMMM
With 2 boys holding some awesome cut-outs like that, How could I say no.  :bigsmile:
Nothing to see here folks, Its just a Bluesmobile.
Offline certifiablecuda
  • Rust Loves Me
    • Certifiable Jeep
« Reply #19 on: December 08, 2008 - 01:03:13 PM »
I have used Auto Rust Technicians for pieces for the rear half of Jeep frames, they are great products and went in pretty easily, just a little tweaking.
I guess it depends on if you want something molded and tweak it or something that is solid...
cb
1971 `Cuda 383 Auto
2005 Dodge Ram CTD 2500
1976 Jeep CJ-5 - RED
1976 Jeep CJ-5 - ORANGE
1978 Jeep CJ-7 - SILVER
1982 Jeep CJ-8 a.k.a Daughter Scramber Project
Offline bb71challenger
« Reply #20 on: December 08, 2008 - 04:21:49 PM »
The reply about torsional stiffness made sense to me. It seems a better fit for me to only weld on each end. I was not looking forward to trial fitting and modifying the pan fit connectors anyway. Nice to have another option out there. If its as strong as stated then it will be both easier to put in and save a lot of time too. I like the look of the rectangular connectors over the pipe style weld/bolt ons that I have seen before.
*Brett*
Offline elitecustombody
  • Supra collector
« Reply #21 on: December 09, 2008 - 05:56:52 PM »
For ultimate results I'd weld ART connectors then weld up the sides using USCartool connectors or just close the sides up with sheetmetal,just spend some time tracing the pattern out with profile gauge, that way the underside will look factory clean and more rigid than a car with ART or USCartool connectors
  Stefan
Stefan B
Offline A R T
« Reply #22 on: December 10, 2008 - 09:03:28 AM »
  Stefan
Stefan, we have 18 gauge steel filler plates for that exact purpose. They cover the gaps, and look pretty clean when installed.
  • Supra collector
« Reply #23 on: December 10, 2008 - 10:27:28 AM »
Great, that will save us alot of time, how much do they run?
Stefan B
Offline Ross
« Reply #24 on: December 10, 2008 - 01:45:43 PM »
 :popcorn:
'70 340 Challenger
A whole lot of rust and very little time to work on it...
Offline Chlngrcrzy
« Reply #25 on: December 10, 2008 - 09:30:36 PM »
Do you have to weld all the way along the plates against the underside of the floor or can you weld spots and then use a filler or something to fill in and smooth the look out?
  • Supra collector
« Reply #26 on: December 10, 2008 - 09:39:02 PM »
I would weld them up completely for best results ,since they don't have flanges or tabs
Stefan B
« Reply #27 on: December 10, 2008 - 11:41:56 PM »
I agree, it would not look as clean with skip welds instead of all around welds.
*Brett*
Offline A R T
« Reply #28 on: December 11, 2008 - 09:12:39 AM »
We don't weld them solid to the floor pan. Its a filler plate, it simply fills in the area between the connector and the floor. No need to be a solid weld. We burn them in where its easy to, then use a good quality flexible seam sealer to dress it up. Its just cosmetic, its not structural in any way. I dont use body filler, as it can crack, or break, plus its a real pain if you need to remove it. On the bottom where it fits to the tube connector, I put plug weld holes, so you can get a good clean look. Sure you have to grind a bit off the top of the weld, depends on your welding abilities, some guys can spin a nice plug weld in there and you can not tell its even there.
I sell then for $39.00 for the 4 of them.
The nice thing about them is its easy to put them in, you can take it and grind a spot, fit it up, maybe grind another spot, fit it up.
I dont care what anyone says, I have never seen 2 cars identical underneath, especially the floors.
  • Supra collector
« Reply #29 on: December 11, 2008 - 12:33:58 PM »
can you make them in 14 or 12 gauge?
Stefan B
