Carlwalski Slideshow
Author Topic: Carlwalski Slideshow  (Read 5702 times)
Offline bentpshrods
  • Almost there, Boise Id.
Re: Carlwalski Slideshow
« Reply #15 on: December 04, 2008 - 03:24:10 PM »
   DANG---and from the pictures your car looked really clean.  Who would of thought you would need all that.   :faint:   When they say beauty is only skin deep --- you hope it is'nt being applied to your car.   :stomp:   You know that in the end you will have a car done right.    :thumbsup:
Offline Carlwalski
« Reply #16 on: December 04, 2008 - 05:10:37 PM »
Thanks Bent, yup, she ain't what anyone thought. Even JUST prior to acid dip you could only tell a few tell-tail signs that there were problems, but not what we got back. Honestly, me and the shop almost thought they had switched cars at the dip shop lol. Oh well, can't do much, as you say, it'll be done right + another E-Body is saved.
Thanks Jim (Slotts). AC/DC fan? "They're OK"  :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
 :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #17 on: December 04, 2008 - 06:11:09 PM »
nice job looks like fun.
Go Fast & Have Fun...
Offline Carlwalski
« Reply #18 on: December 26, 2008 - 05:21:42 PM »
Made another video/slide show.
Vanishing Point to the sounds of Canned Heat - "On the road again". :2thumbs:
    • THE DODGE BOYS
« Reply #19 on: December 26, 2008 - 07:45:04 PM »
thats a cool one also.  :thumbsup:
did you ever get a copy from the movie people for using your car on the DVD?
Offline Bearcuda
« Reply #20 on: December 26, 2008 - 08:36:11 PM »
Cool vid, but I think you might have forgotten someone, er uh, the Jeep?
1973 Cuda 440
1971 Javelin SST
Offline cudadave72
  • you motorboatin sob!!!
« Reply #21 on: December 26, 2008 - 10:03:12 PM »
Awesome vid!!! :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline ragtopdodge
« Reply #22 on: December 31, 2008 - 03:02:53 AM »
Yeah, very sad. I could sit here for a while posting what we found so will just list the parts needed to repair her to better than new below. This (with the Batram purchase) is the reason it's been put on hold. The Batram was my choice and I knew this but Madeline's hiding (very well hidden) body work was TOTALLY unexpected, shocked. Anyhow, I've got a crate that is due to land in NZ next week with the following, I just copied and pasted the Excel sheet. All purchased from Dave @ Roseville......
Roof Skin   AMD   3499   1    $599.95     $509.96     $509.96    Y
Drip Rail (Pair)    AMD   3499-1   1    $199.95     $169.96     $169.96    30 DAYS
Full LH 1/4 Panel    GMK   2422-601-70L   1    $599.95     $509.96     $509.96    Y
Full RH 1/4 Panel    GMK   2422-601-70R   1    $599.95     $509.96     $509.96    Y
LH Gilled Fender   GMK   2422-100-712L   1    $659.95     $560.96     $560.96    45 DAYS
RT Gilled Fender    GMK   2422-100-712R   1    $659.95     $560.96     $560.96    45 DAYS
LT Outer Wheelhouse    GMK   2422-675-70L   1    $109.95     $93.46     $93.46    Y
RH Outer Wheelhouse    GMK   2422-675-70R   1    $109.95     $93.46     $93.46    Y
LH Inner Wheelhouse   AMD   3419IL   1    $139.95     $118.96     $118.96    Y
RH Inner Wheelhouse    AMD   3419IR   1    $139.95     $118.96     $118.96    Y
LT Inner Wheel House Bracket    AMD   3419-1L   1    $17.50     $14.88     $14.88    Y
RT Inner Wheel House Bracket    AMD   3419-1R   1    $17.50     $14.88     $14.88    Y
RH Trunk Gutter    GMK   2422-714-701R   1    $74.95     $63.71     $63.71    Y
LH Trunk Gutter   GMK   2422-714-701L   1    $74.95     $63.71     $63.71    Y
Deck Filler Panel    GMK   2422-710-701   1    $169.95     $144.46     $144.46    Y
Full Trunk Pan   GMK   2422-725-70   1    $349.95     $297.46     $297.46    Y
LH Trunk Floor Extension    GMK   2432-735-70L   1    $109.95     $93.46     $93.46    Y
RH Trunk Floor Extension    GMK   2432-735-70R   1    $109.95     $93.46     $93.46    Y
LT Windshield Corner Cowl Patch (2pc Set)    AMD   3448-2R   1    $99.95     $84.96     $84.96    Y
RT Windshield Corner Cowl Patch (2pc Set)    AMD   3448-2L   1    $99.95     $84.96     $84.96    Y
LT Rear Foot Plan/Footwell Area    GMK   2422-510-70L   1    $99.95     $84.96     $84.96    Y
RT Rear Foot Plan/Footwell Area    GMK   2422-510-70R   1    $99.95     $84.96     $84.96    Y
Rear Crossmember   GMK   2120-790-701   1    $249.95     $212.46     $212.46    Y
Trunk Lock Support    AMD   3428   1    $99.95     $84.96     $84.96    Y
Trunk Lock Shield    BE/A   2218-T   1    $89.00     $75.65     $75.65    Y
Tail Light Panel Filler CORNER Bracket (pair)    AMD   3427-2   1    $79.95     $67.96     $67.96    Y
LH Bracket, Cowl to Fender    GMK   2422-120-701L   1    $19.95     $16.96     $16.96    Y
RH Bracket, Cowl to Fender    GMK   2422-120-701R   1    $19.95     $16.96     $16.96    Y
Rt rear crossmember extension     GMK    2120-790-702R   1    $19.95     $16.96     $16.96    Y
Lt rear crossmember extension    GMK    2120-790-702L   1    $19.95     $16.96     $16.96    Y
70-74 Cuda Shaker hood w/pin hole   AMD   3168SKH-S   1    $995.00     $845.75     $845.75    Y
340 SHAKER KIT    SNOBAR   340SB   1    $2,750.00     $2,400.00     $2,400.00    Y
70 CUDA GO-WING- concours correct   QS   70GO   1    $399.95     $340.00     $340.00    Y
valance support bracket   GMK   2120-790-703   2    $12.95     $11.01     $22.02    Y
spare tire bracket   GMK   2110-726-661   1    $49.95     $42.46     $42.46    Y
Trunk floor braces   GMK   2120-745-70   2    $59.95     $50.96     $101.92    Y
                Sub Total     $8,633.39
             Crating and     Shipping     $650.00    Estimated
                Grand Total     $9,283.39
Thanks to everyone else for the kind words, too nice. :cheers: :thumbsup:
Holy BEJEEZUS!  So sorry to hear.  I must have missed the thread about the big coverup. :bricks1:
That's a whole ton of sheet metal you ordered.  It needed ALL of that or are some of those parts spares???? ???
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline 426HEMI
« Reply #23 on: December 31, 2008 - 05:45:22 AM »
I know the feeling for sure.  Will have about the same to replace on mine.  Just like building a new car for sure.  Could not buy one so will just build one!!!!!!
1970 M46 Barracuda
1998 Dodge Darango
Gordon
nivvy
« Reply #24 on: December 31, 2008 - 09:35:09 AM »
Thanks Neil, yup, lot of parts and a lot of coin, especially as I wasn't expecting it.
It's the resto equivalent of being kicked in the balls with a blindfold on.  :crying:
Never mind, can't do much except soldier on. Time will pass.  :cheers:
Was the 71 cuda full of mud ??? holy parts list. that must suck.......  :faint:
Offline Carlwalski
« Reply #25 on: January 01, 2009 - 02:32:28 AM »
Thanks, I emailed a few months back and it's not released yet. I've done a few Google searches and nothing for: "Blu Ray Vanishing Point" discs etc. I'm not 100% sure if it's the actual Vanishing Point movie or a short 30 minute type documentary, or both.
LMAO! Yup, I didn't have any real decent photos, only like 1 or 2.
Definitely get some nice photos of the Jeep once it's 100%. Well spotted though.
Need them all but we'll work with what we need. I have a very good body guy on the job.
Just as I said, the worst part is no one knew this so it's more shock than anything else.
Yup, just real shlt body work, a real patch up fast and sell job.
Not to worry, she won't know herself when she is complete..............
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #26 on: February 06, 2009 - 03:10:26 AM »
How did you get around using AC/DC music on youtube without them crying about copyright infringements?  See the message below.
"This video contains an audio track that has not been authorized by WMG. The audio has been disabled. More about copyright"
[audio processing in progress]
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Carlwalski
« Reply #27 on: February 06, 2009 - 05:19:34 AM »
Pass..... :lol2:
