You're in the bay area right? If it hasn't already happened this month, go to the mopar alley meeting and ask there, maybe someone will have one or know where to get one. If you know people in the club, I would ask Shelby Wright. I bet he would know who has one.
Sucks that pretty much anything you get is a crapshoot unless you know the seller well. Found a couple on craigslist that might be worth looking into.
Here is one (with an engine if you want to go that way) Closer to Redding:
Dodge 360 V8 and Loadflyte 727 Automatic Transmission - $360 (Biggs Area)
Reply to:
sale-929709105@craigslist.org [?]
Date: 2008-11-22, 9:03AM PST
This is a complete engine and transmission that were removed from a running until wrecked Dodge 1/2 ton pickup. According to the block casting number it is a 1976-1980 LA-series 360 four barrel engine. The block code is 4006830. The intake manifold casting number is 3830945. The carb is a remaunfactured Carter thermoquad. The engine is complete from the fan to flexplate and from the air cleaner to pan. The exhaust manifolds are still installed and I believe the starter is there as well. There is an alternator, power steering pump and an air pump still in place on the front of the engine. All of the linkage for the carb and the transmission are still attached. I ended up with the engine/tranny as a result of a multi-transaction trade and have no use for it. It has been stored indoors since removed and should be in good serviceable condition. I will separate the engine and transmission and sell each individually. The price for the engine is $300 and the transmission is $100. I am open to trades so make me an offer and let's see what we can work out. Email or call Terry at 530 990-1642
it's NOT ok to contact this poster with services or other commercial interests
PostingID: 929709105
I know it might be out of your way, but here are some right down the street from me in Sacramento
HWY 50 / Business 80 / Highway 5 interchange area
mopar 904 & sb727 transmissions - $75 (land park area)
Reply to:
sale-946667751@craigslist.org [?]
Date: 2008-12-05, 3:39PM PST
904 and sb 727 trannys. as pulled. rebuildable cores will run. 75 each. as is
Steve
916 457 8141
