Author Topic: Burnt out resistor on dash wires  (Read 2974 times)
Offline 4yuckfous
« on: December 05, 2008 - 12:12:20 AM »
Somebody knows, that ???
I had in the dash wires a small resistor, the size is about 10 mm long,
this resistor is soldered directly on the wires, without a bracket/holder, nothing.
Nobody can explain me exactly, for what this resistor is.
I need the technical specification to change the defective resistor.
Thanks and greetings from Switzerland.
Andrea
The streets don't get wider, if you drive slower !
Re: Burnt out resistor on dash wires
« Reply #1 on: December 05, 2008 - 12:46:29 AM »
no clue , what color wire is it attached to ?
Offline 4yuckfous
« Reply #2 on: December 05, 2008 - 12:59:55 AM »
I don't find my f.... notes. :clueless:
I will check this today.
There is only one resistor soldred directly in the hole dash wires.
« Reply #3 on: December 05, 2008 - 04:27:56 AM »
Do you happen to have a picture? I have a feeling someone messed with the wiring in your car.
Offline FJ5_440
  • Wisconsin
« Reply #4 on: December 05, 2008 - 07:20:40 AM »
I have seen this done in an attempt to calibrate gauge readings, but this is just a guess.  We can't really tell what it may have been for until we know more about the wire.
** Shane **
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #5 on: December 05, 2008 - 08:33:44 AM »
 :useless:
Offline twist
« Reply #6 on: December 05, 2008 - 08:52:17 AM »
Doesn't the "key in buzzer" use a resistor or diode type setup? I remember looking at it while the dash was out and it seemed to be connected to the headlight buzzer or key in buzzer circuitry.  :dunno:
68 Charger RT
68 Dart GT Convertible
Offline Slotts
« Reply #7 on: December 05, 2008 - 05:31:41 PM »
 :popcorn:
Slotts
Offline 73EStroker
« Reply #8 on: December 07, 2008 - 01:39:16 AM »
A resistor should have coloured bands around it. These determine the resistance and the silver or gold band indicates % accuracy for the resistance level itis supposed to be. Let us know the colours reading from the gold or silver band and I can tell you the value. However, to the best of my knowledge, Mopar did not ever put a resistor in the wiring other than the ballast resistor on the ignition.
Barry (Salmon Arm)
Offline 4yuckfous
« Reply #9 on: December 07, 2008 - 05:08:22 AM »
The supply line has the following colors:
2 x red wires and 2 x black wires with yellow tracer
then the 2-pole connector
on the other side from the connector 1 x red wire and 1 yellow wire with black tracer
On the sticker are the following numbers and letters:
W 96555
2983 595
The letters and numbers on the resistor are not more readable.
Around the resistor (resitors) is a cotton tape.
I don't dare to take away the tape.
Thanks for your support :feedback:
Andrea
Offline 4yuckfous
« Reply #10 on: December 07, 2008 - 07:43:50 AM »
I found it again in the wiring diagram.
Offline 4yuckfous
« Reply #11 on: December 09, 2008 - 03:57:58 PM »
Does somebody know about this diode ? :feedback:
Thanks Andrea
« Reply #12 on: December 09, 2008 - 04:54:41 PM »
well it is clearly a factroy parts & is plugged into the headlight warning buzzer obviously so currnt only flows one direction , not sure what value the diode is as far as curent load but it should be easy enough to replace the diode
« Reply #13 on: December 09, 2008 - 06:29:37 PM »
The diode should have a number on it. Can you see anything?
Offline 4yuckfous
« Reply #14 on: December 10, 2008 - 12:50:14 AM »
Sorry but the diode is burned out, the letters are not more readebel. :pullinghair:
On each side from the wires is a half part from the diode. :clueless:
