Author Topic: wiper blades going off screen...................  (Read 2144 times)
Offline cudaneil
  • Mopar or Nocar ?
« on: December 06, 2008 - 01:44:15 PM »
     HI GUYS,   Cudaneil here.
                                  I have noticed that my windshield wipers go off screen on the passenger side when they sweep.
       And when they stop,they lay at the bottom of the screen,so its not just a case of repositioning the arms.
    Is there a sweep adjustment or is it likely to be wear in something ?        :1zhelp:    :clueless:
« Last Edit: December 06, 2008 - 01:47:18 PM by cudaneil »
just one more job to do..................  (O----{|||}----O)
Offline 422STROKER
  • Member Since 6/3/06
Re: wiper blades going off screen...................
« Reply #1 on: December 06, 2008 - 01:50:07 PM »
What do you mean off the screen?  Maybe you have too long of a blade?
Tom
Tom
Offline cudaneil
  • Mopar or Nocar ?
« Reply #2 on: December 06, 2008 - 01:58:48 PM »
Tom
   Hi Tom,  no what i mean is when the sweep is supposed to stop at the edge of the screen, it actually goes off the edge about 2 inches,and then goes back the other way !
    And the strange thing is,when i get hold of the wiper arm there does not seem to be any excess play in it.
        cheers, Neil.
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #3 on: December 07, 2008 - 01:37:56 AM »
I'm not really sure what you are referring to when you say "screen".   :clueless:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: December 07, 2008 - 01:49:14 AM »
I think he's referring to the windshield.  :grinyes:
Offline cudaneil
  • Mopar or Nocar ?
« Reply #5 on: December 07, 2008 - 02:07:57 AM »
     :roflsmiley: Sorry im English  :england: And we call it a windscreen not windshield.
     Anyhow, the wiper blades are going off the side of the windshield, must be due to adjustment or wear ?   :clueless:
     Thinking about it you guys probably dont need to use wipers much..............but in england we get this thing called rain!   :droolingbounce: (rhymes with PAIN !!!)
« Last Edit: December 07, 2008 - 02:11:57 AM by cudaneil »
« Reply #6 on: December 07, 2008 - 04:01:07 AM »
from what I have figured out the top cover on the 3 speed wipers can be installed  in approx 6 different positions , not sure if this affects the total travel or just the position it parks in , you need to remove the 5 screws around the edge & you will see a pointer tab on the cover , make note of where it is now & try repositioning it
Offline Changin Gears
« Reply #7 on: December 07, 2008 - 08:00:48 AM »
It's in the shop manual, you line up a notch to a groove for A, B, C, E, F etc bodies.
Offline quapman
    • Auto-Grip on Facebook
« Reply #8 on: December 07, 2008 - 10:09:57 AM »
I bet Jules knows!!!!
Jules?
Jules?
Offline cudaneil
  • Mopar or Nocar ?
« Reply #9 on: December 08, 2008 - 10:57:15 AM »
  Hi guys, I just got a pm off jules. He says that the motor camdrive just turns round on the 3 speed motor,so its not responsible for the amount of sweep.
             The extra movement is down to play somewhere in the links or a loose arm on the motor camdrive.
              I think what you guys are talking about with the different cover locations,is just for the "park" positions.   :clueless:
« Last Edit: December 08, 2008 - 11:04:47 AM by cudaneil »
