Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
1970...Steering box....Metric bolts?????
« previous
next »
Print
Pages: [
1
Author
Topic: 1970...Steering box....Metric bolts????? (Read 1716 times)
DAYLEY/CHALLENGER
Resident
Still My Inspiration..1971, Rockingham, Nc
on:
December 06, 2008 - 02:15:12 PM »
I was going to tighten up my steering nut today because it felt like too much play. I had the wife to rotate the steering wheel back and forth while I adjusted the screw. I found that the entire box was loose. The only socket that fit was a 13mm...........Back then I didn'[t think there were metric bolts used.............
Logged
Dave or David
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: 1970...Steering box....Metric bolts?????
Reply #1 on:
December 06, 2008 - 02:42:07 PM »
David, maybe that's the problem..
need me to send my metric wrench set?
Last Edit: December 06, 2008 - 02:51:17 PM by bullitt99
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Alaskan_TA
Guest
Reply #2 on:
December 06, 2008 - 03:10:35 PM »
The originals have a 12 point head, so they take a 1/2" 12 point socket to tighen them.
I would guess that the 1/2 socket you tried is a 6 point, so it would not fit. A 13mm 12 point socket will fit them, but loosely.
Logged
DAYLEY/CHALLENGER
Resident
Reply #3 on:
December 06, 2008 - 05:41:19 PM »
Hey Wade............I actually have a set like that.........
And Barry..........I looked at my sockets.......Yes I tried the reg (which was a 6 point) and the metric..........is a 12 point.........
So folks , it just goes to show there is still information on this site that some of us folks don't know...........Or think about...............
Next time I try out a socket and it won't fit that will remind me to see if it is a 12 point bolt.
Logged
Dave or David
Alaskan_TA
Guest
Reply #4 on:
December 06, 2008 - 07:28:00 PM »
You have already found the only three 12 point bolts on the whole car.
Logged
DAYLEY/CHALLENGER
Resident
Reply #5 on:
December 06, 2008 - 09:46:37 PM »
OOPS..........I only tightened 2.............Guess another trip under the car will be necessary.............Thanks, David
Logged
Dave or David
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
December 06, 2008 - 10:59:25 PM »
Actually there are 2 more in the rear seal plate if you have a big block
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #7 on:
December 06, 2008 - 11:02:32 PM »
Quote from: Chryco Psycho on December 06, 2008 - 10:59:25 PM
Yes, and when you go to tighten them you realize that a 3/8" 12 point isn't in your set.LOL
Tom
Logged
Tom
DAYLEY/CHALLENGER
Resident
Reply #8 on:
December 07, 2008 - 08:47:08 AM »
Now more bolts to look for......with a 440 its kinda tight under there........Thanks guys..........
Logged
Dave or David
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #9 on:
December 07, 2008 - 09:01:32 AM »
2 on top and 1 on the bottom IIRC.
Tom
Logged
Tom
jvike
Full Member
Pro-Touring Cuda
Reply #10 on:
December 08, 2008 - 12:19:37 PM »
13mm = 1/2"
Logged
Roppa440
Full Member
Reply #11 on:
December 10, 2008 - 04:38:22 AM »
Quote from: jvike on December 08, 2008 - 12:19:37 PM
13mm = 1/2"
Nope. 1/2" = 12.7mm.
Close but not close enough if you need to put some weight on it like you do with those steering box bolts. I think they torque to 85lbs or something?
Logged
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
dutch
Sr. Resident
Reply #12 on:
December 10, 2008 - 03:03:21 PM »
close enough......
Logged
*** Bart ***
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
