Author Topic: 1970...Steering box....Metric bolts?????  (Read 1715 times)
Offline DAYLEY/CHALLENGER
« on: December 06, 2008 - 02:15:12 PM »
I was going to tighten up my steering nut today because it felt like too much play.  I had the wife to rotate the steering wheel back and forth while I adjusted the screw.  I found that the entire box was loose.   The only socket that fit was a 13mm...........Back then I didn'[t think there were metric bolts used............. :feedback:
Dave or David
Re: 1970...Steering box....Metric bolts?????
« Reply #1 on: December 06, 2008 - 02:42:07 PM »
David,  maybe that's the problem.. :dogpile:
need me to send my metric wrench set?
« Last Edit: December 06, 2008 - 02:51:17 PM by bullitt99 »
Alaskan_TA
« Reply #2 on: December 06, 2008 - 03:10:35 PM »
The originals have a 12 point head, so they take a 1/2" 12 point socket to tighen them.
I would guess that the 1/2 socket you tried is a 6 point, so it would not fit. A 13mm 12 point socket will fit them, but loosely.
« Reply #3 on: December 06, 2008 - 05:41:19 PM »
Hey Wade............I actually have a set  like that......... :bigsmile: :bigsmile: :roflsmiley:....
And Barry..........I looked at my sockets.......Yes I tried the reg  (which was a 6 point) and the metric..........is a 12 point.........
So folks , it  just goes to show there is still information on this site that some of us folks don't know...........Or think about............... :bigsmile:
Next time I try out a socket and it won't fit that will remind  me to see if it is a 12 point bolt. :cooldancing: :cooldancing:
Dave or David
Alaskan_TA
« Reply #4 on: December 06, 2008 - 07:28:00 PM »
You have already found the only three 12 point bolts on the whole car.   :thumbsup:
« Reply #5 on: December 06, 2008 - 09:46:37 PM »
OOPS..........I only tightened     2.............Guess another trip under the car will be necessary.............Thanks,  David
Dave or David
« Reply #6 on: December 06, 2008 - 10:59:25 PM »
Actually there are 2 more in the rear seal plate if you have a big block
Offline 422STROKER
  • Member Since 6/3/06
« Reply #7 on: December 06, 2008 - 11:02:32 PM »
Yes, and when you go to tighten them you realize that a 3/8" 12 point isn't in your set.LOL
Tom
Tom
« Reply #8 on: December 07, 2008 - 08:47:08 AM »
Now more bolts to look for......with a 440 its kinda tight under there........Thanks guys.......... :working: :working: :bigsmile: :working:
Dave or David
Offline 422STROKER
« Reply #9 on: December 07, 2008 - 09:01:32 AM »
2 on top and 1 on the bottom IIRC.
Tom :2thumbs:
Tom
Offline jvike
  • Pro-Touring Cuda
« Reply #10 on: December 08, 2008 - 12:19:37 PM »
13mm = 1/2"
Offline Roppa440
« Reply #11 on: December 10, 2008 - 04:38:22 AM »
13mm = 1/2"
Nope. 1/2" = 12.7mm.
Close but not close enough if you need to put some weight on it like you do with those steering box bolts. I think they torque to 85lbs or something?
Dave
1970 Challenger R/T
Offline dutch
« Reply #12 on: December 10, 2008 - 03:03:21 PM »
close enough......  :grinyes:
*** Bart ***
