Author Topic: Side glass installation  (Read 3209 times)
Offline Jim
« on: December 06, 2008 - 08:14:24 PM »
Are there any good engineering drawings for how the side glass goes together on a 72 Cuda?
Three of the four windows were installed in my car loose when I got it. No guides or rollers though. I've got the regulator installed on the fourth (front psgr), but I haven't put the glass in yet. I've got a box of window hardware, but really don't know where it all goes.
The FSM is pretty much worthless. Tells how to adjust the glass, but really no good pics of how everything goes together.
Need some help here.  :clueless:
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline HemiOrange70
Re: Side glass installation
« Reply #1 on: December 06, 2008 - 08:40:33 PM »
Hope this helps
Offline Jim
« Reply #2 on: December 06, 2008 - 10:58:51 PM »
 :wow: :bananasmi :cheers: :2thumbs:
-Jim
Alaskan_TA
« Reply #3 on: December 06, 2008 - 11:05:22 PM »
That is for 1970 cars so there will be some differences for a 1972 model. (just so you know)
Offline larry4406
« Reply #4 on: December 07, 2008 - 06:07:32 AM »
Barry - off topic but any update on when the factory drawings are to be made available by Chrysler's sub since you had to stop posting them?  Tried to PM you but your box is full
Offline Gurragas of Sweden
    • Restorers
« Reply #5 on: December 07, 2008 - 06:49:37 AM »
I had my side window out last winter, you need to be two when you put it back.
Offline thedeputy
« Reply #6 on: December 07, 2008 - 12:25:02 PM »
I've just finished the job on my 70 challenger. It's pretty staightforward, and you don't really need an extra hand.
First you bolt in the regulator, then the front and rear guides. make sure you only bolt the guides down at the bottom of the door. If you don't have the catwhiskers in yet, do it now, because it's impossible to do it when the glass is in (even though they say it can be done with the glass installed)
The next step is to lower the window into the door. The tricky part is to get bracket which is mounted to the glass to get it lowered in the door. It helps to keep the catwhiskers out of the way by taping them to the top of the door. Now tilt the glass backwards so the rear bracket is in the door. Now slide the lower front slider into the front track. This is possible because you haven't mounted the top bolt of that track. Then slide in the second one, and the glass is in.
Lower it completely and the mount the horizontal track guide which is still on the regulator assembly.
Now you can roll up the glass and secure the front and rear tracks at the top. keep everything loose until the window rolls up and down freely without any resistance in the mechanisme
Then comes the tricky part of adjusting it. It has to be snug at all the weatherstriping, and also at the quarterwindow.
But al that is pretty straightforward. Also remember to mount the front and rear up-stops when you've adjusted the window.
Good luck and be patient.
Antoon
Alaskan_TA
« Reply #7 on: December 07, 2008 - 02:38:21 PM »
Offline Jim
« Reply #8 on: December 07, 2008 - 05:00:47 PM »
Barry,
You got anything on the rear side glass?
-Jim
Offline the_engineers
« Reply #9 on: December 07, 2008 - 05:05:31 PM »
I'll be putting mine back in this week.  Want some pictures?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Alaskan_TA
