Man you should've posted a pic of the "accidental" burnout
I just got mine started using a hotwire kit, pretty easy really. They seem like good guys too.
I didn't know there was such a section.... I gotta get out more.
So I've messed with the car quite a bit, built a smoke machine with a Air compressor, coffee can and cigar, and could not find a vacuum leak. Called Chris Squier @ Hotwire and he suggested the throttle body was not plugged in correctly. It seems to be. I don't really know what to do at this point. All the codes its throwing are normal according to Hotwire. It just keeps revving up and down.
I did have to swap plugs on the throttle body (different styles between years), which was pretty straight forward, but I will check the wiring on that anyway to make sure I didn't get anything crossed. Glad I saved the old plug.
I've had it on the road and drove it around the block a few times, but it really only idles. I give it gas and it doesn't really do anything in drive. It does rev up some in park or neutral, but not much at all when in drive.
If anyone has some Ideas, I'd sure listen to them...
I need to get my exhaust installed so I can at least run it some to work on it. The whole neighborhood says " what the hell?" every time I start it up and its too loud to think straight.
I hate the idea of having to trailer it to a muffler shop, instead of driving it. It just doesn't seem right.
