Author Topic: Air temp and butt welding panels?  (Read 776 times)
Offline AMXguy
« on: December 08, 2008 - 09:15:23 PM »
I'm  butt welding in a couple lower patch panels and I've done it before with good results , but if you had a choice should you have a cold shop shop so the sheet metal is cold or would you be better off with warmer steel when it comes to warpage? maybe it doesn't matter if you do it right I'm not sure.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline elitecustombody
  • Supra collector
Re: Air temp and butt welding panels?
« Reply #1 on: December 08, 2008 - 09:20:52 PM »
I'd prefer cold shop,but it won't make much difference, I usually use air blower after each spot to keep metal from warping
Stefan B
