Author Topic: Anybody got pics of installed MP Frame Connectors?  (Read 1620 times)
Offline matt63
« on: December 11, 2008 - 11:15:27 AM »
I'm finally thinking about installing the MP frame connectors I bought a year ago.  I got them from Mancini.  They are the bolt in or weld in style.  I was going to bolt them in and them get them welded in later.  I laid them up against the underside yesterday and don't see how the rear section can go over top of the rail without major metal removal on the connector.  They interfere with a couple of things.  Is this right? Has anybody here used these?  Got any pics? Thanks.
ps I couldn't find anything on a search
« Last Edit: December 11, 2008 - 11:44:50 AM by matt63 »
Matt in Edmonton
'68 Valiant
Offline 73Chally
Re: Anybody got pics of installed MP Frame Connectors?
« Reply #1 on: December 11, 2008 - 04:06:02 PM »
I don't have any good pics, but yes, we did have to remove about a 2" x 2" piece of metal from each side at the top where they mounted at the rear.  I had access to a lift and had to use a hydraulic jack to get them snug up against the floorboards.  I know others have been able to get them on with the car on the ground, but it is definitely an exercise in patience.  The payoff is well worth it, though.  Here's what I have.
Offline matt63
« Reply #2 on: December 11, 2008 - 06:13:29 PM »
Thanks for the pics.  So you just cut out pieces so it would slide over top of the rail?
Matt in Edmonton
'68 Valiant
Offline 500Stroker
« Reply #3 on: December 11, 2008 - 06:15:34 PM »
I had to cut a piece out of mine also.
Offline 73Chally
« Reply #4 on: December 11, 2008 - 06:52:15 PM »
That is correct.  AFter we bolted them on, we went back and welded everything, too.
Offline Katfish
  • 70 Challenger
« Reply #5 on: December 11, 2008 - 09:53:35 PM »
Does anyone have a close-up of the rear section that needs modifying?  Can you tell the difference in ride?  What I've noticed when working on my car, if the front-end is jacked up, and I open the doors, you can tell there is some flex because they don't close as well.
Would the connectors cure this?
Offline rusty dodge
  • 74 challenger 440-727-3:55
« Reply #6 on: December 11, 2008 - 10:39:52 PM »
not sure if these are the MP ones, but here is a pic. They fit tight up to the rear floor and actually make the floor bulge up a little.
Offline 426HEMI
« Reply #7 on: December 12, 2008 - 02:49:54 AM »
That looks cool I might do that to mine as well.  Would help with the body pops and things as well.  Gordon
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline Aracer
« Reply #8 on: December 12, 2008 - 03:36:19 PM »
They were hell to fit, because the rear frame rails are narrower in the front that at the rear. So you have to bend the rear of the connector's open channel, up, by using a jack with a wood block (2"x4") underneath  and use vise-grip C clamps to form the sides to the frame. Try to use any existing holes for bolting, and fit some 1/2" pipe stubs inside the hollow area at the front contact point, next to the torsion bar base. They do clear the back floor, and the ride is improved to that of a mini- pick up. The ground clearance is reduced by the extra channel at the back, that can also be removed later. Go for it!
Offline matt63
« Reply #9 on: December 12, 2008 - 04:39:14 PM »
Based on my trial fit a few days ago I would say that is about right.  :)
Matt in Edmonton
'68 Valiant
Offline 500Stroker
« Reply #10 on: December 12, 2008 - 05:48:23 PM »
Yes you will notice the difference on your first drive.  The car feels more solid.  My doors would not open when jacking the front or rear up before adding the connectors.  Afterwards they open fine.
