Author Topic: DASHBOARD IGNITION WARNING LIGHT  (Read 4726 times)
Offline cudaneil
  • Mopar or Nocar ?
« on: December 11, 2008 - 04:16:11 PM »
  Hi,
       Is my car supposed to have an ignition/charge light in the dash cluster . ( The red warning light when you turn on the key)
       It just seems strange that when you turn on the key,nothing lights up.  :clueless:
        Cheers, Cudaneil    :biggrin:
just one more job to do..................  (O----{|||}----O)
Offline 422STROKER
  • Member Since 6/3/06
Re: DASHBOARD IGNITION WARNING LIGHT
« Reply #1 on: December 11, 2008 - 05:28:40 PM »
Do you have a rallye dash?  I have the oil light on my standard dash that lights up with the key in the on position but not running, well except for that time I was cruising to the Fairgrounds at Carlisle and the oil light came on.  Thankfully I had put in a mech guage.  The sending unit wire popped off on my bonzai run.
Tom
Tom
« Reply #2 on: December 11, 2008 - 06:22:22 PM »
If you have a Rally cluster, nothing lights up, but you should at least see the fuel gauge move.
Offline cudaneil
  • Mopar or Nocar ?
« Reply #3 on: December 12, 2008 - 11:10:03 AM »
  Hi,  Yes i have a rally dash, and as you say when you turn on the ignition you just see the fuel gauge move !
        I am used to having a red charging light on every car i ever had.   I wonder if it would be easy to wire in a small red l.e.d. light which comes on with the ignition,
           and goes off after the motor starts ?       :clueless:      Cudaneil.
Offline larry4406
« Reply #4 on: December 13, 2008 - 07:46:38 AM »
What will you gain with this red light?  As you start the engine, the amp gauge should swing from discharge to charge, while the tach shows you the engine is running.
Offline GoodysGotaCuda
« Reply #5 on: December 13, 2008 - 08:22:53 AM »
That usually would require a late model alternator that has a feed/terminal for a light. Little more complicated.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #6 on: December 13, 2008 - 09:12:05 AM »
Solution to adding a idiot light to your Ralley Dash...takes a dual feed oil pressure sending unit.  Here's the how to, see #s 3,4,5 .......................may be a good use for that useless seat belt warning light
http://www.allpar.com/history/mopar/electrical2.html
Offline cudaneil
  • Mopar or Nocar ?
« Reply #7 on: December 13, 2008 - 10:30:27 AM »
          Thanks once again guys !        :wow:  bullitt,  thanks for the website and  article on electricals, it covers everything i wanted to know
                                                         ......awesome !      :2thumbs:  :grinyes:
Offline ShelbyDogg
« Reply #8 on: December 18, 2008 - 10:38:15 PM »
When I turn on my key, my BRAKE light lights up because I always have my parking brake set. Doesn't yours come on?
My black face stereo also lights up and says hello to me.
« Reply #9 on: December 19, 2008 - 09:10:01 AM »
Offline cudaneil
  • Mopar or Nocar ?
« Reply #10 on: December 19, 2008 - 07:10:40 PM »
                    QUICK OPEN THE WINDOWS.............. he-he-he         NICE ONE BULLITT !!!!!
Offline cudaneil
  • Mopar or Nocar ?
« Reply #11 on: December 19, 2008 - 07:14:36 PM »
     No, never use the park brake...........just select park and that locks the transmission.   I will try the park brake and see if the light works !
