Author Topic: Need Front Seat Reinforcing Bracket Info  (Read 818 times)
Offline JeffAARy
  • Orange Mopars Drive Me Wild
« on: December 14, 2008 - 09:55:59 AM »
I'm installing a 4-speed hump this weekend.  My 71 Cuda has replacement floor pans.  The outer most bucket seat mounting locations have reinforcing/load distributing brackets welded to the underside of the floor.  The ones in the middle of the car do not.  Should something be there and the restorers missed it?
Re: Need Front Seat Reinforcing Bracket Info
« Reply #1 on: December 14, 2008 - 11:46:22 PM »
yes , on E bodys the plate was under the floor , on 71 up B bodys the plate was under the carpet
Offline JeffAARy
« Reply #2 on: December 15, 2008 - 12:55:13 AM »
Are they the same bracket as the outer-most locations have?
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: December 15, 2008 - 01:00:02 AM »
here's a pic....hope this helps...
IMO the replacement floor pan seat reinforcements are a little different than the stock ones (my car doesn't have holes in the square reinforcements, the aftermarket floors in the pictured car does) but the material is heavier gauge.
« Last Edit: December 15, 2008 - 02:29:34 AM by ntstlgl1970 »
Offline JeffAARy
« Reply #4 on: December 15, 2008 - 01:24:00 AM »
Thanks, that pic is exactly what I needed!  Now I need to find those inner reinforcing plates somewhere.
Offline moparclown
« Reply #5 on: December 16, 2008 - 05:18:14 AM »
I have both,the square plates and the rocker to floor supports.pm me and I'll dig them out and get pics for you,if your interested?
                                                         Doug
Offline JeffAARy
« Reply #6 on: December 16, 2008 - 10:31:00 AM »
Doug:
Thank you for the offer, but I bought some from Rumblefish.  If anything goes wrong I'll be calling you up though!
