Along with my leaf spring post a realted question
Author Topic: Along with my leaf spring post a realted question  (Read 945 times)
Offline wally426ci
    • maryland mopars
« on: December 14, 2008 - 10:29:28 AM »
How much could you bring the front end down by backing off the torsion bars without effecting tire wear....?  :working:
see how you can see more meat in the front tires? even though the fronts are 14 and 15 in the back, it makes it look like it sags a little....  :dunno:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Along with my leaf spring post a realted question
« Reply #1 on: December 14, 2008 - 11:44:36 AM »
Measured at the wheel lip, you could drop about 1/2 an inch, maybe up to 3/4, without impacting tire wear significantly. Beyond that you'd want to have the camber checked.
Offline 1BADFISH™
« Reply #2 on: December 14, 2008 - 12:00:50 PM »
When we added the leaf to the rear of mine we dropped the front about 1/2" as well just by turning the torsion bars, pretty easy to do.
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
« Reply #3 on: December 14, 2008 - 12:05:26 PM »
I recommend realigning the front end or at laest checking it for toe in
Offline wally426ci
    • maryland mopars
« Reply #4 on: December 14, 2008 - 05:15:38 PM »
good idea guys, I'll get to this in the spring i guess. Too cold.....  :bigshades:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline 72bluNblu
« Reply #5 on: December 14, 2008 - 06:35:22 PM »
You can lower the front quite a bit with the stock bars, but the problem is that as you lower it you have to readjust the camber/caster/ and toe. If you go too low, you'll run out of the stock suspension's adjustability and won't be able to correct it completely. A half inch should be no problem. If you want to really lower it, you might want to invest in some tubular UCA's, most of which have a better out of the box setting for modern tires and are adjustable to boot, to keep the alignment specs in order.
Offline Challenger6pak
« Reply #6 on: December 14, 2008 - 07:59:22 PM »
I believe there is offset ball joints available that are cheaper than new arms but do the same job.
Offline heminut
« Reply #7 on: December 15, 2008 - 10:00:55 AM »
There are no offset ball joints. Moog does make a Problem Solver offset upper control arm bushing set to address the problems with limited adjustability in the Mopars.
1970 5.7 Hemi Cuda
« Reply #8 on: December 15, 2008 - 10:52:28 AM »
Thanks. I knew some type of offset part was available.
