Author Topic: Flywheel bolts too long?  (Read 726 times)
Offline poolboy
  • 1970 R/T 440 4 speed dana 60 3:54
« on: December 14, 2008 - 01:50:50 PM »
I'm putting  the flywheel on the 440 I got with this car and noticed that the flywheel bolts go through the flange and touch the back of the block. They are 1" long which is correct. My question is did these have a washer or lock washer on them from the factory? This would solve my clearance issue or can I just grind an 1/16" off . Thanks
1970 Challenger R/T
1999 Durango -the wife's
2009 Scion xD-daughter's
2003 Dakota Quad Cab-son's
2003 BMW 325i-mine
Re: Flywheel bolts too long?
« Reply #1 on: December 14, 2008 - 03:14:24 PM »
either will work , use a star washer under them or trim off enough to clear , i use locktite too
Offline poolboy
« Reply #2 on: December 14, 2008 - 03:22:59 PM »
Thanks Chryco Psycho. poolboy
1970 Challenger R/T
2003 BMW 325i-mine
