Author Topic: engine block #'s  (Read 1219 times)
Offline 1970-cuda340
engine block #'s
« on: December 15, 2008 - 10:12:36 PM »
Can someone please tell me what these #'s mean stamped on the front of my 340 means? I tried searching and found nothing. :1zhelp:
THANKS!!!!!
    EW340P26390256
Alaskan_TA
Re: engine block #'s
« Reply #1 on: December 15, 2008 - 10:26:10 PM »
EW340P26390256;
E - Series (model year) 1969
W - Windsor Ontario Canada engine assembly plant
340 - 340 CID
P - Premium fuel only
2639 - Date of final engine assembly from the 10,000 day calendar - December 11, 1968 (1969 model year)
0256 - 256th engine assembled at the Windsor plant on the day noted above.
This number is known as the engine serial number, which is not to be confused with the engine VIN number, they are different.
« Reply #2 on: December 16, 2008 - 05:05:26 PM »
Wow,that was fast!!!! I appreciate your help.  :cheers:  :worshippy
Where can I find that kind of info on the web?
Alaskan_TA
« Reply #3 on: December 16, 2008 - 08:26:50 PM »
Well, you just found it here.  ;)
You can get at least part of it at http://www.hamtramck-historical.com/1969-Dodge-TSB-Index.shtml - go there & read TSB # D69-25-1
(Chapter 25 near the bottom of the index)
