I've always been told that U-bolts should never be re-used. I have to take my leaf springs off my axle (long story) and I'm wondering if that applies to my situation.
I installed all of this about two years ago, and since then the car has seen about 2,000 miles. So, if the answer is "You shouldn't re-use u-bolts because they enter plastic deformation when they're tightened" the I shouldn't be using them, but if the answer is "You shouldn't re-use u-bolts because they experience road salts, high stresses and large temp variations which will wekean the steel" then I should be fine.
Thoughts?
