Hi HP2,
Before the T bar swap there were no alignment problems; ride height ok, wheel alignment ok, no pulling into a direction.
After the swap a big pulling to the right, even after 2 visits to two different alignment shops (were I've been before longer ago and where they did a good job, no doubt about their qualities).
What worries/puzzles me the most is that to get the right one in, I had to loosen the LCA completely (no connections to strut rod, shock, UCA and sway bar) and push the LCA further down so the LCA socket would align with the T bar end.
On the left side I could just follow the steps from the manual; remove bump, loosen adjuster bolt and slide in.
As a result on the right side there was already a preload on the T bar and on the left one not, so left adjuster bolt is much further up than the right one. And this was not the case with the old T bars. And indeed the left one is less screwed in than it was with the 0.88 T bar.
So hence my plans to start from scratch to see why there is a difference.
What I hope for a little bit, in a twisted way, is that I pushed that LCA too far down, in stead of lifting it up a bit. Theoretically there are 6 postions of the LCA to let the T bar slide in. At least 4 of them are practically not possible, but I wonder if there are maybe 2 and I chose the wrong one, causing this problem. Sounds perhaps stupid, I know, but I just had to find out what's causing this sh*t.
Perhaps there is an old problem with my suspension that is only noticable with bigger bars...
