Well most people will tell you you are wasting your $$ & the 516 heads are crap ...But I won`t , for a street head they are good , open the exhaust up for the bigger 1.81 valves & install hard seats , you have the advantage of the closed chamber which will help kill detonation & they will make power , I did a set for my Duster & it ran mid 11s weighing in at 3440 lbs with me in the car , it was definatly over 525 HP & ran great , it would have gone faster with better heads for sure but this was back in the mid 80s & not a whole lot of heads were available & they were out of my budget for sure
I ported them using the Mopar templates & did them before I learned & a lot more of the tricks I use today , they will not go out to Max wedge size but you can get them opened up not that size is everything either , velocity makes a big difference as well , shaping around the guide is huge , the templates offer not assistance in that area but you can add swirl & clean up turbulence around the guide , don`t cut into the floor of the port , if anyhting weld some more iron in there lol , I always add some width int he pushrod area but don`t get crazy & break through the wall , this creates a venturi & speeds up air flow behind the valve , I do widen it more at the top where most of the flow is though , & port match the opening , on the exhaust side & widen the port extensively & raise it approx 1/8 ", agin don`t cut into the floor , more floor height is a good thing , I don`t even polish the floors , on the intake side it will help trap raw / unevaporated fuel & on the exhaust side the turbulence will drive the flow higher
the bottom line is you will spend close to $1000 to do a set of 516 heads , unless you do the porting yourself , I Charge $500 to do them so that cuts the cost in 1/2 , to buy Stealths you will spend less but you lose 1 point of compression & may have to address that issue to maximise power & you may need to have the heads checked & fixed for machining quality & you will have to buy better retainers & locks & probably better springs as well so even that may not work out very cheap & any other head is more $$ yet while the 516s will be adequate for a lot of street builds & you say you don`t need crazy , would mid 11s potential be enough ??
