Author Topic: Inside of interior; Rusty roof area What to do  (Read 1969 times)
« on: December 19, 2008 - 07:05:44 PM »
A little afraid on that area being blasted. what did you do? POR? sand blast it anyway?
Offline ntstlgl1970
  • T a c o c a t
Re: Inside of interior; Rusty roof area What to do
« Reply #1 on: December 19, 2008 - 07:34:08 PM »
I had 3 different guys and the blasting place I used recommend the same thing - scuff and seal with POR 15 or some other product. My roof is pretty solid, just looks ugly underneath. Of course there is no way to decide completely without seeing the car. I'm going to scuff and seal mine.
« Reply #2 on: December 19, 2008 - 09:17:46 PM »
I tried wire brushing it but it didn't seem to get the rusty color gone. That Gran coupe headliner glue was fossilized and it seemed to make it harder for the rust look to dissapear. No pitting TG.
I still have some Rust Bullet so probably go use it up.
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #3 on: December 19, 2008 - 09:59:56 PM »
Mine had all that 'scaly' rust, caused by moisture trapped between the headliner and roof.
It's good that you were afraid to blast there.  My media blasting shop refused to blast it, and my body/paint guy agreed with the decision.  Apparently, those roof panels are susceptible to stretching slightly, which can cause your paint to look wavy later.  I went with their recommendation to lightly wire brush it, and seal with POR.
-Tom
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: December 19, 2008 - 10:16:06 PM »
since mine is a GC also, maybe mine does look as bad as yours....
 :dunno:
Offline rallye73
  • Model cars for the big boys!!
« Reply #5 on: December 20, 2008 - 09:54:24 AM »
I cleaned mine using 3in. surface preping disc's. came out real nice.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Offline dutch
« Reply #6 on: December 20, 2008 - 10:02:13 AM »
I used a sandingdisc on the grinder and sealed with por.  one problem occured; when the por had dryed I could see the bar in the middle of the roof on the outside....  :pullinghair:  I guess the por shrinks a little when dry. I still have to cut it loose and see if it takes back the original shape...
*** Bart ***
Alice
« Reply #7 on: December 22, 2008 - 09:07:03 PM »
Avoid POR 15, zerorust is much better product.
Offline 71340RT
« Reply #8 on: December 22, 2008 - 09:29:04 PM »
:iagree: I used the same thing and mine came out great.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline 426HEMI
« Reply #9 on: December 22, 2008 - 10:11:27 PM »
This time I am going to put a new top on my car.  Just did not want to try to finish the under side.   Plus there are some dents in it that would be hard to repair.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Alice
« Reply #10 on: December 24, 2008 - 09:00:48 PM »
If you have dents, it's best to fix them before you put on a vinyl top. A rug will not hide a dent
Offline 360 'CUDA
« Reply #11 on: December 27, 2008 - 03:12:47 PM »
Take a little muriatic acid on a rag and rub. most of the rust color will come off and you can finish with a good wet sanding.
Paint the same day or even the same hour if possible
I used some rustoleum on a car for the under roof and floors.  Came out great
« Last Edit: December 27, 2008 - 03:14:28 PM by 360cuda »
« Reply #12 on: December 27, 2008 - 08:20:49 PM »
Great idea. I just got back from sanding it. I'll get some and try that also.
Offline aussie-e-body
« Reply #13 on: December 28, 2008 - 11:39:17 AM »
this is what i use and i swear by it.you may be able to find something similar on your side
http://www.phoenixpaints.com.au/m_04_01.html.
 :aussie:
i want it all-i want it yesterday-and i want it for nothing
« Reply #14 on: December 28, 2008 - 11:53:36 AM »
hmm,umm,oops.sounds like you may have stretched the roof skin with the sanding disc if you got it too hot.if so you may have to remove the bar and sand that section the same way to stretch it flat again
