If this car was in that bad of an accident, it is mandatory to have it put up on an alignment rack and a frame measuring rack to make sure it is okay. If it was repaired at a body shop I can't think of a reason why they wouldn't check that first. You could have any number of problems, without verifying that the alignment is within specs you can't do much besides a guess. I have seen many suspension pieces that were bent enough to seriously throw off the alignment but have no visual indications of a problem like bends, scrapes, or stress cracking. A few degrees is very hard to eyeball, but is a huge amount of difference in an alignment. Depending on how and where it was hit, it could have a set back wheel now, which will probably total it if the car was that close already. That's still just a guess, first thing to do is get it on an alignment rack.
