Anyone w/an offset leaf spring kit w/sway bar?
Author Topic: Anyone w/an offset leaf spring kit w/sway bar?  (Read 1711 times)
Offline ragtopdodge
« on: December 20, 2008 - 05:58:24 PM »
Thinking of getting a Dr. Diff kit that moves it inboard 1".  ANyone figure out what to do if you try to mate it w/a rear sway bar?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Re: Anyone w/an offset leaf spring kit w/sway bar?
« Reply #1 on: December 20, 2008 - 06:52:46 PM »
Use a B body sway bar. They are a tad bit narrower than an E body unit.
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: December 21, 2008 - 01:36:10 AM »
The E body addco bar that attaches to the axle housing with the u bolts and the end links running to the frame will work with the mopar offset spring hangers (I know you said Dr. Diff, but the setup is probably similar). If you go with super stock springs or anything like that, make sure to increase the front sway bar and/or torsion bar size as well. Running the stock front sway bar and the add on one in the rear can create some dangerous handling tendencies with the super stock springs.
« Reply #3 on: December 21, 2008 - 05:01:28 PM »
Bend the bar
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #4 on: December 21, 2008 - 06:28:32 PM »
Bend the bar
Thats what I did to the e-body bar with my b-body rear set up.
Go Fast & Have Fun...
Offline ragtopdodge
« Reply #5 on: December 21, 2008 - 08:23:32 PM »
YOu used a torch?
06 300c SRT8
04 2500 QCLB 4x4 HO
    • THE DODGE BOYS
« Reply #6 on: December 21, 2008 - 08:27:52 PM »
me :nono:  I had someone use a press at a local shop.
« Reply #7 on: December 21, 2008 - 09:09:43 PM »
I stuck it into the trailer hitch on my truck & pulled like heck ,don`t use heat
Offline miketyler
    • www.miketyler.net
« Reply #8 on: December 25, 2008 - 08:16:47 AM »
good question - let me know what you figure out. I am in the same boat. I thought someone here had redrilled the lower attach brackets. The end links still are pointed slightly inward using this solution I think. Would this be a big deal and/or affect functionality?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #9 on: December 25, 2008 - 02:44:13 PM »
I think Rob redrilled the mounts on his , definatly will not affect function as long as the links are not angled too far & damage the bushings
Offline ShelbyDogg
« Reply #10 on: January 02, 2009 - 10:56:23 AM »
Sorry I'm late on this; too many new threads and topics to accidentally find my name on.
I took my factory sway bar plate and sliced the side support a couple of inches on the side that I wanted to move. I bent it outward, creating a gap.  I then welded in a flat piece of steel to fill the opening and welded it on both sides.  I then drilled a new hole, then snuck up on it's final size, with a die grinder.
I will be making another set for my 2nd challenger sometime soon, so I'll take some pics for my resto-thread.
« Last Edit: January 02, 2009 - 01:54:12 PM by shelbydogg »
Offline Katfish
  • 70 Challenger
« Reply #11 on: January 02, 2009 - 11:02:30 AM »
I have the Dr Diff 1" kit.  I'd like to have the sway bar bent.  How much did it cost, and how did you know how much to bend it.  1" per side?
As it stands, my factory bar is installed to the factory spots, just moved in 1" per side now.
Seems like 1 of the manufacturers would make something up?
