Author Topic: Brake lights and rear hazards not working  (Read 2520 times)
Offline 70 R/T
« on: December 21, 2008 - 01:04:52 AM »
Hi Guys,have a issue with my challengers brake lights not working,all tailights,indicators,side markers are fine,checked switch at pedal and seems fine also,only other non working is rear hazards which i presume is on same cicuit as brake lights,is this a possible fault in my steering coloumn wiring,any help welcome.cheers Paul   :dunno:
Paul
1970 Challenger R/T
1970 Challenger W.S.S
1965 Chev Impala SS
1969 Chev Camaro RS/SS
1972 Chev Corvette Roadster
1975 Pontiac Trans Am
1985 Chev Corvette
Offline duodec
Re: Brake lights and rear hazards not working
« Reply #1 on: December 21, 2008 - 01:58:31 AM »
My '71 had a similar problem that turned out to be in the turn signal switch.  I replaced it and all was well.
Offline willard
    • 1970 Challenger R/T
« Reply #2 on: December 21, 2008 - 03:56:57 AM »
1. check bulbs stop&turn are the same
2. check the signal at the turnsignal switch connector
3. get a wiring diagram and everything will be easier ;)
1970 383 R/T SE
« Reply #3 on: December 21, 2008 - 04:47:30 PM »
Probably in the TS switch , check for power in the wite wire up the column & check for power out to the tailights if power goes in but not out it is the TS switch
Offline 70 R/T
« Reply #4 on: December 21, 2008 - 08:03:17 PM »
Ok,will check out the switch and wiring involved ,thanks for your advice,not so good with wiring issues but am getting better,have just bought multimeter and learning how to use,been more at home with mechanical than electrical issues,cheers Paul :nzflag:
Paul
1970 Challenger R/T
1965 Chev Impala SS
1985 Chev Corvette
Offline 70 R/T
« Reply #5 on: December 23, 2008 - 03:56:44 AM »
Have power at white wire going up coloumn ,which color wires do i check in the loom coming back down,have checked some have power and some not,not sure as color different from loom going up.thanks :dunno:
Paul
1970 Challenger R/T
1965 Chev Impala SS
1985 Chev Corvette
Offline willard
« Reply #6 on: December 23, 2008 - 09:17:42 AM »
the signal to hazard/brake rear lights is:
dark green - LEFT
brown - RIGHT
they should be just by the white wire. Remember they only give signal when hazrd/turn signal/brake connectors are swithed on (eg. hazard switch, turn lever, brak applied). The easiest way is to check em with hazrd lights on (if they work - check front). generally unplug the connector and link white-brown, then white-dark green, right, then left light should turn on (brake applied). If so the turn signal switch is damaged. If not then no curent/broken bulb/wire.
1970 383 R/T SE
Offline 70 R/T
« Reply #7 on: December 30, 2008 - 04:17:44 AM »
Thanks guys,got the brake lights working again ,alot of connection faults.cheers
Paul
1970 Challenger R/T
1965 Chev Impala SS
1985 Chev Corvette
« Reply #8 on: December 30, 2008 - 11:32:55 AM »
 :2thumbs:
