Author Topic: Does anyone make stock appearing steel wheel in 17" and 18"  (Read 1026 times)
« on: December 23, 2008 - 09:18:24 AM »
Hi All!
Does anyone know if stock style steel rims are available in 17" and 18" sizes? I would like to use stock dog dish hub caps on this size of rim to make a T/A clone/style Challenger. I like the look of the stock caps and rims but you can't find good performing rubber in 15"
Thanks Brad
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Does anyone make stock appearing steel wheel in 17" and 18"
« Reply #1 on: December 23, 2008 - 09:48:13 AM »
Give Wheel Vintiques a call. They have several wheels available in the plus sizes that are similar to the factory steel wheel. But because they are billet wheels be prepared to pay. I think they are close to $500 a wheel.
1996 Dodge Viper GTS Coupe
Offline GoodysGotaCuda
« Reply #2 on: December 23, 2008 - 09:50:29 AM »
I have seen them before, they looked pretty well. If you didn't want to run, you can use newer car steel wheels. But they don't quite have the same look
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: December 23, 2008 - 10:53:03 AM »
Plain steel rims, yes, Rallye of magnum style in steel, no. Stockton has made 17" steel wheels that are factory appearing, hence can use dog dish  hubcaps. However, be advised they are not lightweights and will likely come in between 35-40 pounds each. That can be a significant detriment to performance both in a straight line and with handling.
There is still good performing 15" rubber out there, it just isn't easy to find and not cheap when you do find it. For example, Avon 295/50xVR15 with a an A rated traction tread at around $300 each. More reasonable compromise may be the M/T S/R with H speed rating and a new tread design for around $150 each. With the weight your going to be gaining with 17" steel wheels, you may actually  be performance ahead using lighter wheels and lesser quality 15" rubber.
« Last Edit: December 24, 2008 - 07:11:41 AM by HP2 »
« Reply #4 on: December 23, 2008 - 07:38:32 PM »
Thanks guys! I looked but didn't find any 17" or 18" sizes. Maybe you have to phone and order custom?
« Reply #5 on: December 23, 2008 - 07:53:26 PM »
Possibly try over on Moparts.com, may get a little more traffic on the subject. I swear I've seen a car on that site running larger steelies. good luck!
1976 Dodge Warlock
