News:
All the magnum block motor stuff will bolt right on if you get the water pump and everything that bolts to it. Only drawback is you will have to run an electric fuel pump no place to mount the old one the magnum front cover. You can get some decent dress up stuff for that setup.
Im already running an electric fuel pump so that wouldnt be a problem. So a 318 or 360 magnum water pump will bolt right on?
Yes so get r done Get everything from the block forward find a compleet setup so you wont miss any bolts or parts a 360 is the same also.
Have pictures? Isn't the waterpump a reverse flow? How will that work out?
As long as you use the truck fan its not a big deal its made to run in reverse.I will look for some pictures for ya. and check on that bolt hole thing also.
Thanks, I'm curious. I have a MP 360 Magnum block that seems to have most of the correct holes in it, from what I understand. I was told to run the truck/van assembly. I have an electric fan so no need for the truck fan. (if it clears).Not positive the 360 will make it into the car, but would like to know either way. Thanks!
