Author Topic: Througle cable does not reach carb.. Help!!!  (Read 1449 times)
Offline 4THECHALLENGE
« on: December 23, 2008 - 01:52:56 PM »
My 340 has an edelbrock carb and the accelerator cable will not reach, what options do I have? Thank it would help if you posted pics of your 340 so I can see how you made it work. Thanks.. I'd post pics but can't because of my iPhone
Offline femtnmax
Re: Througle cable does not reach carb.. Help!!!
« Reply #1 on: December 23, 2008 - 07:28:44 PM »
I keep hearing talk of different accel cable lengths, where longer cables are needed for certain builds.  Sounds like your is one of them.  Maybe measure your cable length needed and start searching.  I have seen various cable lengths for sale on ebay.
Phil
Offline GoodysGotaCuda
« Reply #2 on: December 23, 2008 - 07:30:22 PM »
I believe there is a throttle cable adapter available from Edelbrock on stock applications.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: December 24, 2008 - 03:18:18 PM »
is it short to the carb or short to the cable mount , it is easy to make an extension to the carb using a chev valve cover load spreader or similar
« Reply #4 on: December 25, 2008 - 01:15:02 AM »
I was think g of using a chevy like set up . It doesn't reach the carb unless I use a clip from the carb to the hair pin to the cable and it looks so ghetto
