Author Topic: What belts should I install?  (Read 785 times)
Offline Jim
« on: December 24, 2008 - 04:04:39 PM »
I'm working towards installing the interior in my Cuda. Shortly, I'm going to need to make a decision regarding what type of seatbelts to install.
Not much original about my interior. I've got a six point cage installed, and there is a mounting tab on the bar behind the seats for a harness anchor point. Seats are from a late model car (not sure what though). I don't intend to install a console.
Anchor holes in the floor are still present and usable. The shoulder belt holes are still present as well, but the cage will probably interfere with any stock-type three point harness. I've used the XV retractable belts in the past on a 71 B-body, but wasn't real impressed.
I've perused the Summit Racing catalog looking for options, but most racing type harnesses have anti-submarine straps which I really don't care to use on a street car. Never bought a racing type harness before, so I'm new to this.
I'm looking for suggestions.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Re: What belts should I install?
« Reply #1 on: December 24, 2008 - 04:14:45 PM »
I would just run what you have , you do not need to install the crotch strap but use the 3" belts with either the lever or cam lock latch designs
Offline Jim
« Reply #2 on: December 24, 2008 - 04:21:35 PM »
I would just run what you have...
Don't have anything at the moment... other than mounting points. :dunno:
-Jim
« Reply #3 on: December 24, 2008 - 04:32:44 PM »
Well RJS is about the cheapest but there are 100 of makes , Simpson if you like brand names , I like the cam lock design better for street use over the lever design
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #4 on: December 24, 2008 - 09:35:26 PM »
racing belts wont pass inspection in ny state
